wat ik heb gedaan :
Ik heb de auto root script gebruikt (van toonrooter) en heb open ocd geinstalleerd omdat ik een nieuwere bootloader heb , nu heb ik de script via een raspberry pi laten draaien en alles ging goed , kreeg netjes de melding van ""je toon is geroot en log nu in via ssh" en had een password , nu kon ik ook gewoon inloggen via ssh via wifi dus dat moet allemaal goed zijn ,
maar het probleem is wanneer ik de update sctript probeer te runnen krijg ik deze error :
login as: root
root@192.168.178.106's password:
eneco-001-286048:~# curl -Nks https://raw.githubusercontent.com/ToonSoftwareColl
ective/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
eneco-001-286048:~# sh /root/update-rooted.sh -f
Welcome to the rooted Toon upgrade script. This script will try to upgrade your Toon using your original connection with Eneco. It will start the VPN if necessa ry.
Version: 4.24 - TheHogNL & TerrorSource & yjb - 6-6-2020
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Only fixing files.
creating backup of inittab...
creating backup of hosts...
cp: can't stat '/HCBv2/etc/qmf_tenant.xml': No such file or directory
FIXING: Trying to fix Global.qml now to add all the Toonstore installed apps aga in.
FIXING: Now fixing internet settings app to fake ST_TUNNEL mode.
FIXING: Now modifying notifications bar to not show any network errors
sed: /HCBv2/etc/qmf_tenant.xml: No such file or directory
sed: /HCBv2/etc/qmf_release.xml: No such file or directory
EDITING: disabling Eneco subscription feature apps to free up memory on this too n 1
cp: can't stat '/HCBv2/qml/config/TenantSettings.json': No such file or director y
sed: /HCBv2/qml/config/TenantSettings.json: No such file or directory
EDITING: disabling KPI and weather happ as these are not necessary on rooted too ns
sed: /HCBv2/etc/qmf_hardware.xml: No such file or directory
EDITING: disabling samba nmbd on toon 1 as probably it is not necessary
File /HCBv2/etc/qmf_tenant.xml was modified but result is an empty file! Trying to restore!
cp: can't stat '/HCBv2/etc/qmf_tenant.xml.save': No such file or directory
Restore of /HCBv2/etc/qmf_tenant.xml is failed! Result is also empty! Please che ck this file before rebooting!
Finished fixing files!
eneco-001-286048:~#
ik hoop dat iemand , mij kan helpen hoe ik b.v aan /HCBv2/etc/qmf_tenant.xml etc kom ,
alvast bedankt
