App ideas / feature requests
Semsemsem
Post by Semsemsem »
I would like to make some app for the toon 2, but I don’t have any great ideas.
So are there any ideas/features that still need to be made?
Preferably useful or fun app ideas.
I already have some experience in qt5, python and JavaScript.
Re: App ideas / feature requests
Post by TheHogNL »
Semsemsem wrote:I would like to make some app for the toon 2, but I don’t have any great ideas.
No there is no list. That would be a great idea already :-)
But you are welcome to review our current apps, all available to see at https://github.com/toonSoftwareCollective/
You could learn from them and even improve the coding if you like.
oepi-loepi
Post by oepi-loepi »
You can also make an animation in Qt5 to use in calender and in the animation app? Some ideas you can find here and are loaded from here.... https://github.com/ToonSoftwareCollecti ... animations
TerrorSource
Post by TerrorSource »
Maybe another package tracking app for other package delivery company's?
I remember that there were a couple ideas already posted on this forum:
TVgids = viewtopic.php?f=97&t=12252
Worldclock = viewtopic.php?f=97&t=12257
oepi-loepi
At this moment wwe are working on a soccer app (voetbal app): select you favourite team (s) and get notified when a goal is scored in a match.
edwin999
Post by edwin999 »
Some more ideas:
- display PM2.5/PM10 Particulate Matter (fijnstof) from a nearby station
https://www.samenmetenaanluchtkwaliteit ... -interface
https://github.com/opendata-stuttgart/meta/wiki/EN-APIs
(or use your own device https://sensor.community/en/sensors/airrohr/)
- display CO2 value
from Netatmo device https://dev.netatmo.com/
from Aranet4 device https://github.com/Anrijs/Aranet4-Python
from homebuilt device MH-Z19B sensor + Wemos D1 Mini V3 microcontroller
Ron_nl
Post by Ron_nl »
I would love to have a tile like edwin999 a posting above gave as an idea.
I do have such a PM2.5 etc. device which gives a .json output file.
software_version "NRZ-2020-129"
age "112"
sensordatavalues
0
value_type "SDS_P1"
value "6.95"
1
value_type "SDS_P2"
value "6.10"
2
value_type "BME280_temperature"
value "11.57"
3
value_type "BME280_pressure"
value "101238.88"
4
value_type "BME280_humidity"
value "96.29"
5
value_type "samples"
value "4342259"
6
value_type "min_micro"
value "33"
7
value_type "max_micro"
value "20522"
8
value_type "signal"
value "-85"
Values 0 - 4 are the most important. (for me)
Or by IP-device/values
Home » Huidige data
115 seconden sinds laatste meting.
Sensor Parameter Waarde
SDS011 PM2.5 6.4 µg/m³
SDS011 PM10 7.2 µg/m³
BMP/E280 Temperatuur 11.5 °C
BMP/E280 Luchtdruk 1012.35 hPa
BMP/E280 Rel. luchtvochtigheid 96.4 %
WiFi Signaalsterkte -86 dBm
WiFi Signaalkwaliteit 28 %
Ron.
Templar
Post by Templar »
Extend the Boilerstatus app to include a screen with OpenTherm Monitor Graphs.
http://otgw.tclcode.com/otmonitor.html
Prutzer
Post by Prutzer »
Is it possible to create in the STC menu a option for a sheduled reboot?
It would be nice to reboot toon once a week because toon gets very slow after a week uptime.
mAiden
Post by mAiden »
Prutzer wrote:Is it possible to create in the STC menu a option for a sheduled reboot?
Login to ssh of you're Toon
opkg install http://files.domoticaforum.eu/uploads/T ... r8_qb2.ipk
if you did that, then you ready for the next step
crontab -e
And add line below
20 4 * * 3 reboot >/dev/null 2>&1
This will be reboot you're Toon every wed on 4:20am
jblokzijl
Post by jblokzijl »
Is there a way to display the output of https://pvoutput.org/ on a hacked Toon?
OR.....A lot of solar panel owners use a SolarEdge inverter....wouldn't it be cool to have an app on the Toon to show your KWH? Would anyone be willing to look into it? SolarEdge has a full fledged API : solaredge.com/sites/default/files/se_mo ... ng_api.pdf
you can fully integrate it with ZonOpToon using this solution:
viewtopic.php?f=95&t=12896&p=95404&hili ... dge#p95404
jblokzijl
Post by jblokzijl »
Toonz wrote:you can fully integrate it with ZonOpToon using this solution:
I would net a step by step dummy guide to accomplish this ;-)
edwin999
Post by edwin999 »
edwin999 wrote:Some more ideas:
- display CO2 value
An easier site to use is from luchtmeetnet https://api-docs.luchtmeetnet.nl
Example: https://api.luchtmeetnet.nl/open_api/co ... =51.924452
This can be used for current and predicted values of
Stikstofdioxide (NO2)
Fijn stof (PM10)
Ozon (O3)
Luchtkwaliteitsindex (LKI)
lijkt bruikbaar inderdaad
