How to save Monitor mode state?
vamp
Post by vamp »
Hello there,
I would like to use the OTGW with monitor mode. I able to set it with otmonitor, but every restart it chnange back to Gateway mode. How to save the actual mode?
Re: How to save Monitor mode state?
There is currently no way to run the OTGW in monitor mode, other than sending it the GW=0 command after each restart.
Recently I made a change to have the DHW mode setting survive a restart. I will look into doing the same for Monitor mode.
Starting with 4.2.8, the monitor mode setting is saved in EEPROM. Once configured using GW=0, the OTGW will continue to run in monitor mode following a restart.
vamp
Post by vamp »
Great, thanks a lot!!
