How to save Monitor mode state?
Posted: Tue Dec 08, 2020 10:05 am
by vamp
Hello there,
I would like to use the OTGW with monitor mode. I able to set it with otmonitor, but every restart it chnange back to Gateway mode. How to save the actual mode?
Re: How to save Monitor mode state?
Posted: Thu Dec 10, 2020 9:54 pm
by hvxl
There is currently no way to run the OTGW in monitor mode, other than sending it the GW=0 command after each restart.
Recently I made a change to have the DHW mode setting survive a restart. I will look into doing the same for Monitor mode.
Posted: Sun Dec 27, 2020 7:22 pm
by hvxl
Starting with 4.2.8, the monitor mode setting is saved in EEPROM. Once configured using GW=0, the OTGW will continue to run in monitor mode following a restart.
Posted: Sat Jan 16, 2021 1:54 pm
by vamp
Great, thanks a lot!!
