Toon ssh file creation and editing
Jasper
Post by Jasper »
For the home assistant control panel to work on Toon I need to create a key holder file.
I've found the right location using ls -al /mnt/data/tsc/homeassistant.token.txt and now I'd like to edit it so I can paste the key.
Problem is that I can access the folder with ssh but not with ftp. It doesn't even want to connect with the Toon. Used port 22 and 21 with ftp and doesn't connect.
So I thought I could "nano homeassistant.token.txt" though nano isn't installed I think.
Is there another way to do this?
Templar
Re: Toon ssh file creation and editing
Post by Templar »
Jasper wrote:Hi,
You can use vi. But I use WinSCP with the SCP protocol on port 22 with succes.
Jasper
Post by Jasper »
I'll try winscp tomorrow when I'm home. All I have now is my phone.
