Undocumented error code MPC
mvn23
Post by mvn23 »
While playing around with the new firmware v5.0 I ran into the following:
command: C2=9.999
reponse: MPC
Unfortunately I can't find this error code anywhere in the docs.
I'm guessing it has something to do with the float parsing (C2=9.99 is accepted without issues) but I would like to get some more info on this.
Also, if anyone is aware of any more such codes, sharing is appreciated ;)
Re: Undocumented error code MPC
:lol: MPC is not an error code. The letters represent the settings for LEDs D,E, and F. You get this output because the result of the subroutine to parse a floating point number is incorrectly interpreted as a pointer to an error code in EEPROM. Because you used 9.999, you get the data at offset 9. If you try 4.999, you get all LEDs: "L=FXOMPC". And 15.999 returns "A=OpenTherm Gateway 5.0". Needless to say, this is another bug.
I've created a test for both of your findings in the test suite. So they will be verified before I release a new firmware version in the future. I've also added a test for OT=-0.004, which should round up to 0.00. At least that one already works correctly.
It looks like you are stress-testing the firmware. Do let me know if you find more bugs.
mvn23
Post by mvn23 »
Haha that's awesome! Thanks for the info. I already added an 'MPC' error code in my dev version of pyotgw :lol: guess I'll have to remove it again.
I'm trying to cover all of the more or less reasonable user inputs for the pyotgw update. If I find anything else I will of course update on this forum.
