MoreSense CO2, Hum, Temp, Indoor Air MQTT Sensor
HI Guys
Picking up the hobby a bit again.
I found this nice MQTT AirSensor Display from Lars Who is building these nice gadgets
Very Nice thing About it That you can Also Display your own status text via MQTT on the panel
Also all the values can be send to via MQTT to Homey, Home Assistant, Domoticz or your own system (in my case)
25cm x 13 cm x 4cm
Wifi
Diff Colors
Bosch BME60 Sensor
SenseAir CO2
Temp
Air Pressure
Humidity
IAQ
Rotate
Beeps
MQTT
Rest API
Wifi Socket connector
Etc.
I have no Commercial stake in this at all and i also do not get discount :-)
Check his website, I think his new sensor is not on there yet, because its brand new.
https://link.marktplaats.nl/m1786053871
https://moresense-nl.com/
Akatar
Re: MoreSense CO2, Hum, Temp, Indoor Air MQTT Sensor
Post by Akatar »
Looks interesting, did you already buy one?
if so, let us know what you think
yes i bought one, its working great, and displaying mqtt messages is cool
firmware request are handled fast also
abl
Post by abl »
Built an Awtrix 2 last year, which has a sort of app-store with lots of interesting stuff. But the real nice thing is that you can also feed the display with messages (and animations) via MQTT. Very cool to build (having access to a laser cutter at home helps :) ) and a real eye-catcher when running.
fhughes
Post by fhughes »
What kind of message do you send via mqtt? Just the data or more complex messages with text/images etc.
fhughes
Post by fhughes »
I am using it mainly for data display, but also animations like hearts blinking during a heartbeat measurement, and other small effects. For example when someone is home I can display "Welcome Home" on the screen. The possibilities are endless!
