Rooting a Toon in Spain: SOS!
AnD!
Post by AnD! »
Hi there!
I am writing because I would like to root my Toon (it's a Toon 1; Repsol-Viesgo, Spain) and I have no idea how to do it, although I have seen the tutorial about it :roll:
So, could someone from Spain do it for me? Thanks!
Regards
Re: Rooting a Toon in Spain: SOS!
Post by TheHogNL »
AnD! wrote:Hi there!
Regards
Hi, easiest is to do it yourself using this method: https://github.com/JackV2020/Root-A-Toon-USB-Stick
Should work for the Viesgo also.
AnD!
Post by AnD! »
Regards
Thank you!!!
Hi, if you want apps to be translated into Spanish, just let me know. Happy to facilitate.
Also, if you want new apps for Spain specifically I can look into that as well.
AnD!
Post by AnD! »
Toonz wrote:Hi, if you want apps to be translated into Spanish, just let me know. Happy to facilitate.
Hi! That would be great! My computer skills are of an advanced home user, but I can help translate from English to Spanish :)
Keep in touch!
TheWiZaRD_RGP
Post by TheWiZaRD_RGP »
Hi!! I am from Spain also, I have Repsol as energy and gas provider.
Have you been able to do it? If possible I would like to ask you for help!!
AnD!
Post by AnD! »
TheWiZaRD_RGP wrote:Hi!! I am from Spain also, I have Repsol as energy and gas provider.
Hi! Yes: I got it :) I just followed the method suggested by TheHogNL (https://github.com/JackV2020/Root-A-Toon-USB-Stick; thanks again!) step by step. The only problem I have now is accessing Toon outside home, but that's a problem with my router and my internet provider: Orange (I'm on it!).
TheWiZaRD_RGP
I tried to send you a private message but I am not sure if it worked.
Currently my toons shows me the instant energy consumption, the cost (but is always shows 0 EUR), the burning time working of the boiler, and of course the thermostat and 4 options and a possibility of making programs.
It will be the same later?
Post by TheHogNL »
TheWiZaRD_RGP wrote:I tried to send you a private message but I am not sure if it worked.
After rooting this will all still be available but even more options will be added.
Only thing you can't do is to use any remote access your provider is giving you to the Toon. You need to create your own remote access afterwards.
enriquemp
Post by enriquemp »
Hi spanish friends!
I have a Toon from Repsol. I have just rooted it and integrated in Home Assistant.
I can control the temperature, the programs (home, outside, confort and sleep) but reading the electricity and gas values is not working.
Have to been able to get it working?
Thanks in advance!
Post by TheHogNL »
enriquemp wrote: Tue Jun 14, 2022 11:25 am Hi spanish friends!
Thanks in advance!
Interested to look into this. There is only one or two other spanish members here. Can I take a look from the Netherlands at your Toon? I'll send you a private message for my contact details.
enriquemp
Post by enriquemp »
Cool. Happy to help if I can.
I will contact you in private via Whatsapp
El_perry
Post by El_perry »
Hello my friends.
I am also interested in this topic could you help me please.
My electricity provider no longer supports Toon. :( :( :(
Thanks
oepi-loepi
Post by oepi-loepi »
El_perry
Post by El_perry »
Ok thanks muy friend.
I'll take a look at it and see what I can do.
The computer level is very bad.
Return to “Toon Rooting”
