monitoring Toon 2 humidity sensor
If you don't know where to post, post here.
ikookmaar
Post by ikookmaar »
Hi Toon experts!
Does anyone know if / where the Toon 2 's humidity sensor can be read remotely?
Is the humidity percentage visible at some sort of URL and can it be retrieved biy some json string (so I can show it in Domoticz)?
Thanks in advance...
ikookmaar
Re: monitoring Toon 2 humidity sensor
Post by ikookmaar »
Oh, just found http://my.toon2.ip.adress/tsc/sensors:
{"temperature":18.1, "humidity":77.2, "tvoc":892, "eco2":2087, "intensity":0}
Now let's find out how to get the humidity value into Domotcz...
madpatrick
Post by madpatrick »
Maybe this will help you.
It is a Dzvents script (not tested, because it is a snip from my total Toon script)
viewtopic.php?p=100776&hilit=script#p100776
local ToonTempHum           = 588                                           --   Vochtsensor ID
return {
        on          = { timer = {'every minute'},
        logging     = { level = domoticz.LOG_ERROR, -- change to domoticz.LOG_ERROR when all OK
                        marker      = scriptVar
execute = function(domoticz)
        local ToonIP                = domoticz.variables('UV_ToonIP').value         --   IP address of your Toon
-- Vochtsensor
        local handle3 = assert(io.popen(string.format('curl http://%s//tsc/sensors', ToonIP)))
        local TSCsensors = handle3:read('*all')
        handle3:close()
        jsonTSCsensors = json:decode(TSCsensors)
-- Update the BoilerMoisture sensor to current value
        local TSCsensors_hum = tonumber(jsonTSCsensors.humidity)
        local TSCsensors_temp = tonumber(jsonTSCsensors.temperature)
        domoticz.devices(ToonTempHum).updateTempHum(TSCsensors_temp,TSCsensors_hum).silent()
   end
2022-10-23 10_00_17-Domoticz - Temperatuur.png (13.36 KiB) Viewed 6602 times
ikookmaar
Post by ikookmaar »
Wow, thanks.
I did some research and after lots of trial and error got this to update an perccentage switch.
But your script seems much nicer and combines temperature and humidity into one device...
local scriptVar = 'humidityRetrieved'
return
on =
timer =
'every 5 minutes' -- to trigger the request
-- devices =
-- 'JSONTrigger' -- to trigger the request during development / test
httpResponses =
scriptVar, -- must match with the callback passed to the openURL command
logging =
level = domoticz.LOG_INFO,
marker = scriptVar,
execute = function(dz, item)
if item.isTimer or item.isDevice
then
dz.openURL(
url = 'http://my-toon-ip/tsc/sensors',
method = 'GET',
callback = scriptVar, -- see httpResponses above.
else
if item.ok then
myJSON = ( item.isJSON and item.json ) or dz.utils.fromJSON(item.data) -- JSON to Lua table ( also when not recognized as JSON )
if _G.logLevel == dz.LOG_DEBUG then
dz.utils.dumpTable(myJSON) -- show structure of converted JSON -- ( only for debug )
end
local humidityValue = dz.utils.round(myJSON["humidity"], 0)
dz.log("Toon luchtvochtigheid = ".. humidityValue .. "%",dz.LOG_DEBUG)
-- update Toon Humidity device in DomotiZ
dz.devices('Toon luchtvochtigheid').updatePercentage(humidityValue)
else
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
end
end
end
madpatrick
You need to use the Temp+Hum sensor type as a virtual switch
P.S. can you use <code> when posting a part of the script.
See </> button above the text box
Makes it more readable.....
Return to “Toon miscellaneous”
