Hi, I have build the OTGW form nodo shop.
The gateway works fine but sometimes in runs into error 03 situation and the thermostat displays no communication.
It sometimes happens after day’s or sometimes after e few hours when the gateway was started.
When I look at the signal with my oscilloscope then is can see the difference between normal and error situation.
The difference is that in normal operation I see 1 volt data bits in the signal and in the error state it’s almost 0.5 volt data bits.
How can I fix this problem?
Opentherm Gateway Stops working with error 03 at random times
- Starting Member
Re: Opentherm Gateway Stops working with error 03 at random times
You'll need to provide a lot more information to be able to give any relevant advice. Error 03 normally only means that one single message was deformed. That should not be a big deal, and the thermostat simply requests the message again. When reporting a problem like this, a log showing the issue would be very helpful.
Also, indicating you measured something without revealing where you measured doesn't really provide any useful information. You should normally see a voltage swing of at least 8V on the opentherm line for communication from master to slave. But communication from slave to master happens using different current levels. These should in theory not be visible when measuring the voltage, as you would normally do with an oscilloscope. In practice, you can actually see the signals leak through into the voltage in most cases, but with a much lower amplitude. Maybe that explains the voltage difference you saw. I really can't tell based on the provided information.
- Starting Member
In the documentation I saw that error 03 can occur if a reference voltage is not correct.
So I have now turned the voltage up a bit. And now I it's not running into a error 03 situation for almost a day now.
Now I see error 03 messages 15 per hour and still no communication error on the thermostat.
I have attached two images of the signal measured at the boiler site of the gateway.
These pictures are from the current "no problem" state.
If the problem occurs again I will capature the signal and attach these again.
The logfile when it was in error 03 state looks like this:
13:36:57.276629 Error 03
13:36:57.961657 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:36:58.291074 Error 03
13:36:58.902528 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:36:59.107565 Error 03
13:43:51.016156 Error 03
13:43:51.621347 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:51.910265 Error 03
13:43:52.569606 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:52.723669 Error 03
13:43:53.147490 PR: A=OpenTherm Gateway 6.4
13:43:53.503524 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:53.733581 Error 03
13:43:54.446035 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:54.750219 Error 03
13:43:55.407988 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:55.559667 Error 03
13:43:56.347507 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:56.577781 Error 03
13:43:57.297169 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:57.592076 Error 03
13:43:58.241755 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:58.404536 Error 03
13:43:59.180071 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:43:59.422276 Error 03
13:44:00.125112 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:00.439916 Error 03
13:44:01.061723 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:01.252632 Error 03
13:44:02.012448 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:02.269330 Error 03
13:44:02.943457 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:03.279748 Error 03
13:44:03.887990 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:04.094364 Error 03
13:44:04.827829 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:05.109900 Error 03
13:44:05.797473 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:06.126400 Error 03
13:44:06.737918 T00560000 Read-Data Remote parameter settings V/H (MsgID=86): 00000000 00000000
13:44:06.940019 Error 03
13:44:07.141063 OT: 13.40
13:44:07.393805 SC: 13:44/7
13:44:07.431914 PR: G=00
13:44:07.478967 PR: I=11
13:44:07.544699 PR: O=N
13:44:07.588737 PS: 1
13:44:07.631170 00000000/00000000,0.00,00000000/00000000,0.00,0.00,0.00,0/0,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,13.40,0.00,0.00,0,0/0,0/0,0.00,0.00,00000000/00000000,0,0,0,0,0,0,0,0,0,0
13:44:07.956773 Error 03
13:44:08.766206 Error 03
13:44:09.784485 Error 03
13:44:10.798146 Error 03
13:44:11.614953 Error 03
13:44:14.300093 Error 03
13:44:16.182111 Error 03
13:44:18.068766 Error 03
13:44:19.332585 Error 03
13:44:20.142328 Error 03
13:44:21.157035 Error 03
13:44:21.973867 Error 03
13:44:22.988999 Error 03
13:44:24.000920 Error 03
13:44:25.018976 Error 03
13:44:25.830186 Error 03
13:44:26.851566 Error 03
13:44:27.862318 Error 03
13:44:28.678932 Error 03
13:44:29.689597 Error 03
13:44:30.506725 Error 03
13:44:31.519324 Error 03
13:44:32.533315 Error 03
13:44:33.345699 Error 03
13:44:34.368412 Error 03
13:44:35.382139 Error 03
13:44:36.189721 Error 03
13:44:37.141471 OT: 13.40
13:44:37.406227 SC: 13:44/7
13:44:37.438145 PR: G=00
13:44:37.479834 PR: I=11
13:44:37.519516 PR: O=N
13:44:37.561324 PS: 1
13:44:37.604172 00000000/00000000,0.00,00000000/00000000,0.00,0.00,Error 03
13:44:37.639686 0.00,0/0,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,13.40,0.00,0.00,0,0/0,0/0,0.00,0.00,00000000/00000000,0,0,0,0,0,0,0,0,0,0
13:44:38.226234 Error 03
13:50:31.190570 Command: PR=W
13:50:32.388784 Command: PR=L
13:50:54.940409 Error 03
13:50:54.977455 Error 03
13:50:55.015253 Error 03
13:50:55.051193 Error 03
13:50:55.090572 Error 03
13:50:55.125428 Error 03
13:50:55.162353 Error 03
13:50:55.197066 Error 03
13:50:55.227568 Error 03
13:50:55.261342 Error 03
13:50:55.294493 Error 03
13:50:55.329769 Error 03
13:50:55.366680 Error 03
13:50:55.404014 Error 03
13:50:55.447252 Error 03
- IMAGE2.jpg (25.75 KiB) Viewed 1575 times
- IMAGE1.jpg (25.29 KiB) Viewed 1575 times
The PS=1 command causes logging to stop. You may want to use the "Resume normal logging after a summary report" option introduced in OTmonitor 6.4.
Those are some nice scope pictures. Mine isn't so advanced that I can save screen shots.
It's a bit strange that your baseline in IMAGE1 varies. That looks like the scope is in AC mode, although it says CH1:DC. Or is that just the trigger and does b~ actually mean AC? Anyway, it shows what I mentioned: The signal on the left is the opentherm message from the OTGW to the boiler, that uses voltage levels, with around 8V difference. The signal in the middle is the response from the boiler. The current changes used to convey the message result in small voltage differences. But the voltages are meaningless. The information is in the current.
