Toon App: Conway's Game of Life
JackV
Post by JackV »
My implementation of Conway's Game of Life on Toon can be found on https://github.com/JackV2020/life
For those who do not know what it is .... Wikipedia : https://en.wikipedia.org/wiki/Conway%27s_Game_of_Life
The Game of Life, also known simply as Life, is a cellular automaton devised by the British mathematician John Horton Conway in 1970.
You can create your own shapes and select from some predefined shapes.
At this moment there is a scrolling pull down menu which has 14 presets including so called oscillators, spaceships, guns which produce gliders and of course an option which puts TOON on the screen. I plan to make more presets.
(For developers : I created ScrollMenu.qml which is a very configurable object which you are free to use in your projects. Shows a button and when you click it the menu drops down over all what is on screen. Also over siblings you defined later in your qml. Hides when you made a selection or auto-hides after a configurable time in seconds. Takes an input array with your options, returns the index and value of the selected item and sends a signal on which you can act and has many settings for shaping and coloring.)
There are some 'Themes' which define the shapes and colors of the cells and a button to start and pause Life. When Life is running and Toon goes into dimState it stays on the screen and the colors change to the theme settings for dimState.
Enjoy Life :)
