I am trying to make a rather simple extension of my 'automated home'.
However one of the SAIX12 modules does not seem to work as i expect, or i do something really stupid
This is a discription of my setup for the SAIX12 :
-lightsensor (klemko IBE-12/LI) build in outside light
-lightsensor toggles 220volt, on/off wire connecting purple wire of SAIX12
-SAIX12 is supposed to toggle the garden lighting wire (220 volts)
This is functional:
When programming the SAIX12 as 'wandcontactdoos/wall-outlet' i can command the SAIX12, and garden lights go on/off.
This is my problem:
Reading from the manual, i believe the correct programming should be 'beweginsmelder/motionsensor' to have the unit react to the purple wire also which is his trigger then.
Programming seems to work good, but the SAIX12 does not seem to react correctly on the 220 volts on the purple wire.
What am i doing wrong ?
Grtz,
ron
Xanura HCB, and some interfaces, and loads of wishes...
