saix12 fuzziness ?
Posted: Sat Sep 13, 2008 8:58 pm
by acfnews
Hi All,
I am trying to make a rather simple extension of my 'automated home'.
However one of the SAIX12 modules does not seem to work as i expect, or i do something really stupid :-)
This is a discription of my setup for the SAIX12 :
-lightsensor (klemko IBE-12/LI) build in outside light
-lightsensor toggles 220volt, on/off wire connecting purple wire of SAIX12
-SAIX12 is supposed to toggle the garden lighting wire (220 volts)
This is functional:
When programming the SAIX12 as 'wandcontactdoos/wall-outlet' i can command the SAIX12, and garden lights go on/off.
This is my problem:
Reading from the manual, i believe the correct programming should be 'beweginsmelder/motionsensor' to have the unit react to the purple wire also which is his trigger then.
Programming seems to work good, but the SAIX12 does not seem to react correctly on the 220 volts on the purple wire.
What am i doing wrong ?
Grtz,
ron
Xanura HCB, and some interfaces, and loads of wishes...
saix12 fuzziness ?
Posted: Sun Sep 14, 2008 6:30 pm
by MindBender
Xanura inputs works with both a momentary as a regular switch, without further configuration: Applying or removing power to/from its input <i>toggles</i> the output instead of switching it on or off, just like applying a pulse to the input.
You need a sensor input module, or configure the SAIX12 for a sensor.
saix12 fuzziness ?
Posted: Fri Sep 19, 2008 8:39 pm
by acfnews
Hi MindBender,
Thanks for the advise.
Ik configured the SAIX12 as 'bewegingsmelder/motionsensor' and it does seem to work now.
However i did have issues programming the unit.
Before i started (module builded away) it was not responding to any X10 signals. Only after re-programming, the unit works as expected.
Re--programming took me 3 attempts before i got the unit to work in sensor mode.
This is quit typical behaviour, and i will keep an eye on the module.
A friend of mine has another unit, will play with that also to get more familiar with these SAIX12's.
Thansk again,
ron
saix12 fuzziness ?
Posted: Thu Oct 02, 2008 7:50 am
by acfnews
All,
After the last programming two weeks ago, yesterday the problem did re-appear.
I could read status from the SAIX12, but could not toggle the lights on/off via X10.
After a removing the power from the unit, and applying power again things seem to work now.
It looks almost if the circuity towards the relay is acting funny now and then.
My friend with 3 SAIX12's (we bought them together) already had 2 replaced, but issues here also.
After loading the latest firmware 1.4.15.983 i hoped this was improved as Xanura mentions again support for their new models (inc SAIX12)in the release notes.
Any thoughts ? Looks like two issue here, but both in the same new SAIX12 modules...
saix12 fuzziness ?
Posted: Tue Nov 11, 2008 9:28 pm
by acfnews
All,
Last weekend did some experimenting with multiple SAIX12's, while programming with/via HCB.
Found one little issue which i believe is a bug. Can someone confirm this behaviour :
-program SAIX12 as wall-outlet or motion-detect
-leave checkbox next to 'send status load' empty
This should make the unit work as expected.
When programming the unit with 'send status load' checked on, the relais function does not seem to work anymore.
Would really appreciate some comments....
<font size="1">Xanura HCB, and some interfaces, and loads of wishes...</font id="size1">
