Command sends via websocket ends with timeout
rpav
Post by rpav »
I guess I have already faced the same problem, but can't remember the solution:
Once I try to send commad via websocket, for example:
http://myserver:8080/command?CS=30
It ends with "timeout".
I can see the command in the log:
10:24:19.617963  T00550000  Read-Data   Inlet fan speed: 0
10:24:19.630313  R80750000  Read-Data   CH pump starts: 0
10:24:19.656622  Command (via websocket from 192.168.62.3:49122): CS=30
10:24:19.780322  B40751CDC  Read-Ack    CH pump starts: 7388
10:24:19.791429  AF0550000  Unk-DataId  Inlet fan speed: 0
But it seems it is not executed. Any suggestion?
Thank you,
Roman
Re: Command sends via websocket ends with timeout
Which firmware? There was a fix for a similar problem in 6.2/5.5.
