Fibaro smartplugs not detected after rooting
casimex
Post by casimex »
I've successfully rooted my Engie Boxx (BE version of Toon). Everything seems to work fine except that I cannot reuse my Fibaros Zwave smartplugs.
It is like they are not detected anymore even after pressing the small button 3 times as explained.
I've also tried to "repair" them through the menu but nothing changes.
Is there anything more to do after rooting to be able to use zwaves smartplugs?
Thanks for you help
oepi-loepi
Re: Fibaro smartplugs not detected after rooting
Post by oepi-loepi »
They should be able to pair. I know some are hard to pair and the sometimes need a factory reset before they are able to pair. Keep trying, they will also pair on a rooted toon (or boxx).
casimex
Post by casimex »
Thanks for you reply.
I already did a full reset as explained here: https://www.youtube.com/watch?v=EhQt47W8wDg
But still nothing.
Are they any zwave logs somewhere?
Akatar
Post by Akatar »
try to exclude the plugs first and then include.
casimex
Post by casimex »
It finally worked after several hard reset.
Thanks all for your help!
Return to “Toon Rooting”
