Toon values overwritten by P1 values via HA
If you don't know where to post, post here.
Pandabeer35
Post by Pandabeer35 »
hardware: Rooted Toon 2 / latest software version
I want to use my P1 USB cable together with Home Assistant to get more data out of my Smart Meter (like phase 1,2,3 info) This new meter has DSMR 5.5 - Now I have the Toon meter module linked to the P1 connector as well a Zonneplan module (with a active/powered splitter)
I don't want to use an extra splitter so my setup can be hopefully the followint
--------> P1 USB to Home Assistant
P1 meter (DSMR 5.5) ---> powered splitter
--------> Zonneplan One
Now my question, instead of reading values (via Home Assistant) from the Toon module - How can I sent these values for Gas, Electricity to the Toon (rooted) - using Home Assistant (with NodeRed)
Thank you for your help in advance,
Peter
oepi-loepi
Re: Toon values overwritten by P1 values via HA
Post by oepi-loepi »
You cannot. You will need the toon meter module for that.
Return to “Toon miscellaneous”
