I have a problem with my toon incombination with a external temp sensor, yesterday i have been busy with home assistant to create a temp log and to get it on toon, that works then i edited a file so toon doesnt use the internal temp sensor but getting the data out of that file and that worked.
but it's not stable and like now the temp shows 0,0 c nothing changed and the file keeps updating and does show the right value like now the file shows 23
any advice how i can fix this ?
Toon 1 Rooted + External temp sensor
- Starting Member
- toontemp.jpg (35.28 KiB) Viewed 12057 times
- Starting Member
Re: Toon 1 Rooted + External temp sensor
After i posted this it started working again without modifications but the last few days its working and then the temp goes to 0c toon does this random, also the time when it's down is also random.
i checked the temp sensor it self but that value didnt change so it must be toon that doesnt like this idea i guess ?
i'm going for the backup plan and create a whole system for this in my HA with external temp sensor, it only controls floor heating that is on or off so for me its easy
Still it would be nice if the toon works but my best guess is that is has to many restrictions
