Reset plugwise
Reset plugwise
Sometimes plugwise plugs will not join the network.
This happens if the factor rest did not work okay.
For resetting:
Just plug the adapter
wait for click
remove wait 3 sec.
plug wait 3 sec
remove wait 3 sec
plug wait 3 sec
remove wait 3 sec
plug ..rest is don.
I'm using a simple Homeseer event and TM13 for resetting
For resetting:
wait for click
remove wait 3 sec.
plug wait 3 sec
remove wait 3 sec
plug wait 3 sec
remove wait 3 sec
plug ..rest is don.
Reset plugwise
Chak,
Wait for a click is not correct. (helpdesk Plugwise)
Go direct for de plug and unplug procedure.
Gr Ruud
Gr Ruud
Reset plugwise
agreed, this reset is missing one step.
as per the plugwise site http://forum.plugwise.com/viewtopic.php?f=29&t=114 :
Soms moet de Circle+ ge-reset worden. Dat kunt u doen door de Circle+ plug driemaal achter elkaar in het stopcontact te steken en er weer uit te halen.
Telkens gedurende 2,5 seconde.
as in:
plug in for 3 secs
remove for 3 secs
plug in for 3 secs
remove for 3 secs
plug in for 3 secs
remove for 3 secs
then plug it in and it should work.
as in:
plug in for 3 secs
remove for 3 secs
plug in for 3 secs
remove for 3 secs
plug in for 3 secs
remove for 3 secs
Reset plugwise
Okay..
This will not change anything in reseting..
Both methods work.. I have done this many times.
Reset plugwise
Chak,
Is this also reset the power usage counter?
gr Ruud
gr Ruud
Reset plugwise
yes.
you need also reset it in the software.
Reset plugwise
Hi Chak,
How do i reset a circle usage in the software?
gr Ruud
gr Ruud
Reset plugwise
You can't reset the plug from the software..only reset the data counters in the software.
Reset plugwise
That was the question!
How to reset the usage for a circle in de software.
gr Ruud
gr Ruud
Reset plugwise
Go to config (instellingen)
Devices (apparaten)
select the device
just click on the zero button behind the total usage
Devices (apparaten)
select the device
Reset plugwise
Sorry for the question. but that simple!
Thanks .
Thanks .
Reset plugwise
I have a problem with the software of plugwise.
All the circles have the sign "?".
The stick is also blocked.
This is since novembre 25.
See picture below.
What to do?
B.R. Wim [:)] [;)]
See picture below.
What to do?
B.R. Wim [:)] [;)]
Reset plugwise
A reset for backward to the factory setup isn't work by the circles till now.
How can you futher unblock the stick?
BR. Wim [:)] [;)]
BR. Wim [:)] [;)]
Reset plugwise
You can try running the config.wizard.
Start->All Program's->Plugwise Source->Configuratiewizard
This will reconnect all devices, if they are reset.
Reset plugwise
Hallo Reinder,
I tried that too, but in the configuration wizard, I come till part 1: Put Stick in pc and wait till a "vink" is coming in. But that isn't happen.
What can I do to reset the stick?
BR. Wim [:)] [;)]
BR. Wim [:)] [;)]
