<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by I-1</i><br />
It was shipped with Active Home (Windows based piece of software)
I installed the software and tested it ... and it worked fine.
It works <i>barely</i>, not <i>fine</i>. As a manufacturer I would be embarrased for this piece of cr*p, but at least it's not defective
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I was wondering if there are also Linux based software arround to do the same stuff you can do with Active Home.
Actually, I'm working on that right now. For power consumption reasons I bought myself an EPIA M9000 mainboard (with soldered-on C7 processor @933MHz). It's not as beefy as the servers most people in this group are using, but it's consumption averages down to 13 Watts. A Watt/Year costs 1.89 Euro nowadays, so a 100 Watt server would boost your electricity bill by 189 Euro per year. To compensate for the lack of processing power I will be using Linux. After all, all the systems has to do is to run a webserver and to send/receive a couple of X10 commands. I'm don't think I will make a freely configurable user application. Instead I will probably hard-code all my devices' behaviour because it's much quicker to implement and because it's a 1-off solution. I can keep you posted if you want.<br />
By the way, I'll be using a 8GiB CompactFlash card as a hard disk to save even more power.
