What options do I have to place a motion sensor outside? (weather proof)
I have an RFXCOM for X10/Oregon/Visonic
Thank you!
DJ
Motion Sensor Outisde - which to buy?
MS13
Kaku outside version.
standard 220v motion sensor with SAIX12/AIX12
I use the MS13.
Not sure what Chak is suggesting with the 220v.
The one I have runs on batteries.
http://www.waakzaamwonen.nl/catalog/pro ... geheugen-2
If you already have a good motion sensor just connect the saix12/aix12 behind the current 220v sensor and you have your trigger in HS.
MS13 too with batteries. I use IKEA batteries, very low price! They are since 2 months at -2 , -7 C and still working. About weather protection: not sure they are IP66 full, i put them in those little plastic houses for birds where they have bath......perfect to locate on trees!
Me too - MS13 with batteries. They are supposed to be waterproof but keeping them under shelter is probably a good idea. They work perfectly with an RFXCOM receiver. Since they contain a day/night sensor in them too, you might want to position them away from any lights they control!
Steve
Steve
I'm using MS13 and MS16 too! i fitted them with Lithium batteries.. I still using them since jan 2007 until now. havent changed any batteries.
