Nice to see that water is growing when it is hot.
Nice Free water [:D].
http://www.bwired.nl/Water.asp
The total use is zero and the hot use is 7L.
Waarom zelf het wiel nog een keer uitvinden.
Expansie water
Expansie water
can't figur that out myself
looks like my boiler is damping hot water, but then it needs cold water to heat up again, and there is no water used?
Could be that the meter is not OK, Need to investigate this.
Expansie water
I sometimes see my hot water meter running (even backwards!) without water usage, i think it is caused by pressure differences.
Expansie water
Yes you are right thats the problem!
My hot water meter is very close connected to the HVAC system.
Mostly my boiler is heating up for a few moments when I flush the toilet
also pressure related.
I will check the loggings of my boiler to see if they match.
Thanks
Thanks
Expansie water
BTW. When I look ad your Toilets meter I se more then 11 days in date different.
Is this right.
Is this right.
