RFXcom and Cinemar Mainlobby
angel
Post by angel »
Hello, i just obtained several RFXcom boxes and i have centered the automation of my house around Cinemar's mainlobby. Does anyone have any experience on how to get the responses from the the RFX receiver into Mainlobby? I would be very happy to get some guidance here as the connection between the sensors and the receiver work fine, as well as with the software which cvomes along with it. Now the last part of getting the responses in Mainlobby would be great!
Thanks in advance, Anjo
angel
Post by angel »
Excuse my ignorance. Have now, after several tries, connected through the W800rf interface and get my data in Cinemar. Sorry for the polution!
anjo
angel
Post by angel »
If however anybody has any ideas on how to do this properly, please let me know as i do see the data, but am somewhat lost in formatting it.
Also are there any example db's on how to write the data from the RFXcom into msaccess or any other format.
Regs
Anjo
b_weijenberg
Post by b_weijenberg »
The W800 operates in 32 bits mode and is able to receive X10 sensors and X10 remotes.
If you connect the RFXCOM receiver to software with the W800 driver you have to initialize the RFXCOM receiver in 32 bits mode.
Use RFreceiver (stop ML before!) and select 32 bits mode. This mode setting is saved in the receiver and it will operate like a W800.
Droezel
Post by Droezel »
I'm using RFXcom and Mainlobby, but I also use Homeseer. So my setup is: RFX Hardware -> Homeseer RFXcom Plugin -> Homeseer -> MHLSPlugin -> MLServer.
