Page 1 of 2
RFXCOM's Receiever/Transmitter with Ethernet.
Posted: Thu Mar 12, 2009 2:45 am
by y0ngg
I have been trying the whole day connecting the lan cable to the cpu.
at the very first try, i successfully detected the transmitter&receiever. after several tries later, i failed to detect and yet it prompt me with "The active network interface on this computer is using Auto-IP address."
Anyone experienced such incident?
Please kindly share with me how it can be solved.
Thank you very much. ;]
Posted: Thu Mar 12, 2009 4:45 am
by y0ngg
i mean i couldn't find the ethernet interface that i wanted to connect through the lantronix deviceinstaller.
could anyone who knows how to solve this problem help out me?
greatly appreciated
thank you.
Posted: Thu Mar 12, 2009 8:20 am
by b_weijenberg
Posted: Thu Mar 12, 2009 8:56 am
by y0ngg
is that the only way to solve?
how do i know that i had actually locked out myself due to wrong lan/wlan configuration?
awwws. so sorry to prompt up so many questions at a go ;/
Posted: Thu Mar 12, 2009 11:20 am
by y0ngg
heres another problem that i might face? or might not.
am i able to use the transmitter and reciever w/ ethernet interface to retrieve signals that my sensors noted then using the computer to collect those information from the transmitter and reciever.
in chapter9, im no longer going to use the ethernet interface, then will i still be able to retrieve those signals?
bah. kind of confusing for me as a newbie =/ sorry
Posted: Thu Mar 12, 2009 11:28 am
by y0ngg
opps. my bad
didnt read clearly regarding the RS232
RS232 Serial Interface module.
This module is equipped with a 9 pins SUB-D connector and will be delivered with a back panel for the Ethernet Interfaces.
This module needs 1 port of the USB, LAN, WLAN interface.
so another question i have is actually which one i should remove?
i have one which is with the antenna(green led) on jp4 and another one which is with the yellow wire as antenna i suppose(red led) on jp6.
Posted: Thu Mar 12, 2009 12:02 pm
by b_weijenberg
Remove the receiver(s) from the interface so that JP4 and JP5 are free.
Insert the RS232 interface in JP4 or JP5
Connect the RS232 to the PC using a cable with these connections:
Pin 2 pin 3
Pin 3 pin 2
Pin 5 pin 5
Start Hyperterminal 9600baud, No parity, 8 bits, 1 stop, no handshake
Press and hold the x on the keyboard and power up the interface.
The interface should respond now and you are able to configure the interface with the proper settings.
Posted: Fri Mar 13, 2009 3:32 am
by y0ngg
thanks alot bert ;]
hopefully everything is gonna be solved.
Posted: Fri Mar 13, 2009 5:38 am
by y0ngg
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by b_weijenberg</i>
<br />Remove the receiver(s) from the interface so that JP4 and JP5 are free.
Pin 2 pin 3
Pin 3 pin 2
Pin 5 pin 5
sorry. but im kind of confused.
so i will have a cable which one side is the 9pin and anothher side will be .... ?
you said i will have to connect to the computer with the following connection :
pin 3 pin 2
pin 2 pin 3
pin 5 pin 5
so i will have to get a cable with two different ends?
once again sorry to trouble you.
Posted: Fri Mar 13, 2009 8:12 am
by Fantic
this is when you have a serial connection on your PC which nowadays is always a male DB9. When your PC does not have a serial connector, then you need to find yourself a serial to USB convertor and hook the above described cable to this convertor install the driers and go.
Regards, Maarten.
Posted: Fri Mar 13, 2009 8:21 am
by y0ngg
hmms okay.
i will try to inform my supervisor about it.
thanks alot maarten ;]
Posted: Fri Mar 13, 2009 9:11 am
by y0ngg
so i have to set to Com 1.
then 9600baud, 8bits, 1 stop, no parity and none on the hyperterminal?
Posted: Fri Mar 13, 2009 10:07 am
by Post-IT
I used a null-modem cable, worked like a charm.
Start your terminal, hold the x while powering the device. It will state you'll have to press enter to enter installation mode.
Chapter 9:
http://www.rfxcom.com/documents/RFXCOM_ ... erface.pdf
Posted: Fri Mar 13, 2009 11:10 am
by y0ngg
hmms. im currently using vista.
any suitable hyperterminal programme that you guys would recommend?
Posted: Fri Mar 13, 2009 11:35 am
by b_weijenberg
See chapter 9
Where is documented in point 4:
Start a terminal emulator.
HyperTerminal can be used in Windows. For Vista or Linux you can use PuTTY for example.
http://www.chiark.greenend.org.uk/~sgtatham/putty/
