Reading through all posts on the PMIX35 its clear there is a plugin available for Homeseer. I tried to find it but did not Succeed. Can somebody point me in the right direction??
Francois
Homeseer V2, RFXcom receiver, Harrisson Electric Curtains, Touchscreen + homebrew interface. DigiBee+, Velleman Relay board, homebrew optocoupler interface, homebrew Aritech interface, homebrew DigiBee-Homeseer interface.
Which Plugin for PMIX35 and Homeseer?
Isn't it the same of CTX35? I think so. Other ideas?
Yep it's the same as the CTX35
ACT TI103
ACT TI103
Thx.
I have seen that one, but the homeseer site says its RS232 instead of USB. Do I need a third party virtual com driver?
Francois
Francois
Driver on the CD will install USB <> RS232 convert driver.
In Homeseer just select the new com poort.
Chack is right. My case is: a SERIAL CTX35 , plugged on a rs232-usb adapter (lack of com port in my notebook). I use a virtual com port created by drivers. when i start HS , i have an error on COM port but it works perfectly anyway. Cheers, Lorenzo
@Lorenzo,
I have also the startup error this is because of the short timeout in the ACT TI103 plugin.
Also the PMX35 will show the same error at startup.
Thanks Chak. I'm also using your txt instructions to open com port in HS .ini file. Isn't there a way to solve this little problem? Lorenzo
Same error here, but also no problems while operating.
Running the PMIX35 with the ACT TI103 plugin from the homeseer updater (2.0.0.5) connected using the Belkin USB/Ethernet hub.
Seems to run smoothly, thanks for pointing me in the right (plug-in) direction.
What would be nice is to have a couple of virtual devices that reflect the diagnostics info from the PMIX, something like "Last Voltage", "Noise" and "impedance". This will of course require an expanded plugin, does such a thing exist?
Francois
Francois
Yep..that is what I'm also looking for..
I hope one of the developers is interested in building a plugin...
