Can not callibrate gas Device
Post by Harry »
I like to recalibrate my Gas device.
but get a rollover error when do so.
i use rfxcom pulse to monitor the gasmeter(little miror).
this is working fine now for a year or so.
after a day of now power on the device (instalation work in the meter closed)
a have to recallibrate.
homeseer gives a few more m3 then the meter.
and have to downcalibrate.
up calibrating is working but down i get the rollover error.
i have try'd to delete and re adding the device,now success.
i use
Versions:
RFXCOM plug-in: 12.0.0.33
b_weijenberg
Post by b_weijenberg »
Set the device value manually to zero using the HS Control page.
The counter rollover will no longer appear and the device will be updated.
Post by Harry »
thx that did the trick
