Wanted: basic IP video observation set
Moderator: Esteban
Dear domotica friends,
I'm looking for a lowcost basic IP-observation video set.
I want to use a few basic Axis IP CAM's (with audio)
and some basic PC-hardware.
So the main interest is for the software.
A Win solution is OK, but Linux is fine also.
My user requirement:
- support for 1-4 IP-cam's
- life view & listen
- Push-To-Talk button for talking back
- easy to use
- limited PC hardware performance (old-PC should be OK)
And nice to have but not a requirement:
- logging
- web interface
And....I don't want to pay much because I'm dutch.
Looking forward for your suggestions...
With best domotica regards,
- easy to use
- logging
- web interface
4 IP Cams need some power to run without pauses in live video. Even recording needs power. I use a good software that manages 2 ip cam with pan & tilt and recording with a centrino 1.5GHz , 512 mb ram winXP. 25 USD and 15 days to try.
http://blueirissoftware.com/index.html
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by drmacchi</i>
<br />I use a good software [...] http://blueirissoftware.com/index.html
Is this supporting Audio listen and Push-To-Talk ?
Listen Audio, yes . Push to talk i dont' think. Then your cams should have hardware feature to "push to talk"
For most solutions I'm afraid it's gonna cost ya a fair amount for what you want to do. <s>The basic Axis cameras only have one-way sound (from cam to user) as far as I know. Unless you consider e.g. the 210A (500/600eur x4) and the likes 'basic' as well.</s>
<s>If you want to pay as little as possible, Using analog cameras with an one quad Axis Encoder (e.g. AXIS 241QA, 800/900eur) might be a cheaper option But if you want to be able to talk separately to every camera, that won't work as the encoder only supports one mic-in and one line-out. Also you'll need to wire the audio separately. Simply using a non audio encoder and a soundcard might be an option as well.</s>
Good luck,
Esteban
See below: The Axis M1031 is a cheaper solution.
Good luck,
Esteban
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Esteban</i>
<br />The basic Axis cameras only have one-way sound (from cam to user) as far as I know.
The low cost Axis M1031 supports 2-way audio.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rklootwijk</i>
<br />Have a look at Zoneminder (http://www.zoneminder.com), it's open source and runs on Linux.
But no sound support either.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by LittleBit</i>
<br />The low cost Axis M1031 supports 2-way audio.
You're right, hadn't seen on this model that it did two-way. Thanks
- Faizal
- Starting Member
Re: Wanted: basic IP video observation set
Does anyone uses this with Homeseer Pro 2.5 ?http://blueirissoftware.com/index.html
I have 3 IPcams AVTECH AVI202 and they can´t be used directly in Homeseer.
Groeten, regards,
Faizal Walidin
HomeSeer Pro 2
Faizal Walidin
HomeSeer Pro 2
It looks like there's a trial version available, so you should be able to give it a spin.
- Faizal
- Starting Member
Dear Estaban,
I'll try, but I was wondering about the isseus with Homeseer Pro, in the trail I hope it works with my camera's.
Groeten, regards,
Faizal Walidin
HomeSeer Pro 2
Faizal Walidin
HomeSeer Pro 2
Hi, i have a license of that sw. I have used it , but you must have a dedicated server for that. It creates a web page that can be shared with Homeseer. The problem is : a lot of CPU and RAM to use for that, if you want live , full frame video. If you, only, need some snapshots, that's not a big problem.
Don't you think it's better a "movement detection" from cams, i use some PT cheap China cams that have this feature, they take snapshot and send via mail or ftp.
then homeseer can even , with "an event" move the cam towards where you need, using some MS13 detectors, and take more screenshots of the "bad people"
Ciao
Ciao
- Faizal
- Starting Member
I think I'm going to give it a trail, I have a Windows 2008 X64 server, i7 with 24GB internal memory.
Groeten, regards,
Faizal Walidin
HomeSeer Pro 2
Faizal Walidin
HomeSeer Pro 2
ONLY 24 GB ??????????????'
