I have an old Powermax alarm system (433Mhz) and the panel has stopped working. Does anyone know where I could obtain a replacement (cannot find one in the uk) or alternatively is there another system I could use that would still allow me to use all my existing PIRs/ detectors?
Thanks,
Paul
Powermax help
Powermax help
Hi Paul,
Is this what you are looking for?
http://www.waakzaamwonen.nl/catalog/ind ... c-powermax
Lennart
Lennart
Powermax help
Lennart,
It looks different from the panel that I have but I assume that so long as it is a 433 system then it should work.
Many thanks,
Paul
Many thanks,
Paul
Powermax help
Hi Paul,
Have a look at http://www.waakzaamwonen.nl/catalog/ind ... toebehoren to see if your sensors are on this page. If so, I guess it's safe to try.
Lennart
Lennart
Powermax help
They seem to be all 868Mhz systems so maybe it won't work. I've emailed them to ask.
Powermax help
Hi Paul,
Yes, of course. I forgot: Visonic is 868 over here, so it won't work with these standard versions... Sorry. Maybe Waakzaamwonen can get you a 433 MHz version, so good thing that you mailed them. And otherwise: did you check eBay, etc.?
Lennart
Lennart
Powermax help
I've looked on ebay but nothing there at the moment.
- b_weijenberg
Powermax help
Check with Mario from http://www.domolandia.com
In Spain they use the 433 version.
