RFXMeter
Antoon
RFXMeter
Post by Antoon »
Today I installed my RFXMeter with 3 puls modules.
I have installed my Eltako DSZ12D Kwh meter and want connect this to the RFXMeter.
In HS I see the three RFX devices.
RFXPwr is now on 10.00 units.
My Eltako has 1000 pulses for 1 Kwh.
How do I setup this, can't find it in the manual or I overlooked.
- Antoon
<h6>HomeSeer 2.3.0.19
ACTTI103,BLAB8SS,BLMediaPlayer,DooNetwork,BLEditor,BLOccupied,DooMotion,ActiveBackup Plugin,BLGarbage,BLRandom,NetCAM,pjcOutlook, YACSeer,DooCPU Monitor, HSTouch Server,RFXCOM, BLRfid</h6>
RFXMeter
Do you mean regarding hardware or software?
If you mean hardware look at chapter 5.4 of http://www.rfxcom.com/documents/RFXPulse%20module.pdf
The S0 acts as a dry contact.
Antoon
RFXMeter
Post by Antoon »
I have make the connection now and it is counting also.
Have set the value divide by to 1000 is that correct?
- Antoon
<h6>
Lennart
RFXMeter
Post by Lennart »
Yes. I'm using 2000 pulses/kWh meters and I'm using a "divide by 2000" in the RFXcom HS plugin.
Lennart
Antoon
RFXMeter
Post by Antoon »
Oke thanks,
Thats working.
Now I am gonna connect the gasmeter.
- Antoon
<h6>
RFXMeter
Take your time with that one, you'll probably need to do some adjustments to the potmeters before you get the best results.
Antoon
RFXMeter
Post by Antoon »
yes,indeed.
But it is working already, after that I make the adjustments.
Now waiting voor my water meter.
Does somebody know how to set the divide by the virtual devices for day usage and instant usage?
- Antoon
<h6>
