Best way to adjust the puls metering for gas
Antoon
Post by Antoon »
It was not so simple as I thougt.
Adjusting the pulsmeter for gas this weekend and tought is was working ok.
But the gasmeter is only counting when the light in the cellar is on.
When I set the trigger a little bit higher then the led goes on and stays on.
I have try to set the sensitive lower and the distance higher but it is not counting correct with the cellar light off.
What is the best way to setup this thing?
- Antoon
<h6>HomeSeer 2.3.0.19
ACTTI103,BLAB8SS,BLMediaPlayer,DooNetwork,BLEditor,BLOccupied,DooMotion,ActiveBackup Plugin,BLGarbage,BLRandom,NetCAM,pjcOutlook, YACSeer,DooCPU Monitor, HSTouch Server,RFXCOM, BLRfid</h6>
Antoon
Post by Antoon »
Ok after searching for hours I found the problem.
When I was put on the lamp in the celler where also the gasmeter is hanging the light was shining on the glass from the meter.
Making the glass black with some paper and the problem was solved [:D]
- Antoon
<h6>
