Best way to adjust the puls metering for gas
Posted: Mon Apr 27, 2009 10:17 pm
It was not so simple as I thougt.
Adjusting the pulsmeter for gas this weekend and tought is was working ok.
But the gasmeter is only counting when the light in the cellar is on.
When I set the trigger a little bit higher then the led goes on and stays on.
I have try to set the sensitive lower and the distance higher but it is not counting correct with the cellar light off.
What is the best way to setup this thing?
- Antoon
<h6>HomeSeer 2.3.0.19
ACTTI103,BLAB8SS,BLMediaPlayer,DooNetwork,BLEditor,BLOccupied,DooMotion,ActiveBackup Plugin,BLGarbage,BLRandom,NetCAM,pjcOutlook, YACSeer,DooCPU Monitor, HSTouch Server,RFXCOM, BLRfid</h6>
- Antoon
