help: Input Sensor 1 is not the Input Sensor Message Panel
Noel
Post by Noel »
I'm getting the following error in my HomeSeer startup<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Error RFXCOM Input Sensor 1 is not the Input Sensor Message Panel! Assign another device code to Input Sensor 1<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'm sure it's fixed easely, but how?
Thank you.
Antoon
Post by Antoon »
I think you have used the first input device for another device while it is reserved for the sensor message panel.
- Antoon
<h6>
Noel
Post by Noel »
Hi Antoon,
It's set to the sensor message panel (it did this by it self).
I'll remove all the panel sensor's and see if it will fix it.
Noel
Post by Noel »
Hmmm not so nice. I can not delete the [1 to [4 sensors.
I get a "RFXCOM system panels can not be deleted."
This is what I have from [1 to [4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Alarm Panel State [1 System RFXCOM Alarm Panel State ALARM[1]Q
Alarm Panel Status [2 System RFXCOM Alarm Panel Status ALARM[2]Q
Alarm Panel Display [3 System RFXCOM Alarm Panel Messages ALARM[3]Q
Alarm Panel Control [4 System RFXCOM Alarm Panel Control ALARM[4]Q<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
b_weijenberg
Post by b_weijenberg »
Input Sensor Message Panel is different device than the security panels.
You should change the Input sensor having address 1 and assign another device number to that sensor using MOFIFY in the RFXCOM - Input Dev. configuration panel.
Noel
Post by Noel »
I do not have anything assigned to address 1 in RFXcom > Input Dev.
The 1st sensor in Input Dev. starts with nr. \6
In RFXcom > Security I do have [1, but that can not be modified or deleted.
b_weijenberg
I suppose that after removing all DooNetwork devices that where using the RFXCOM Input devices house code including \1 the problem is solved?
Noel
Post by Noel »
re: I suppose that after removing all DooNetwork devices that where using the RFXCOM Input devices house code including \1 the problem is solved?
Yes.
For some reason one of my DooNetwork devices also got a \1 house code.
After your suggestion of removing it, it fixed the problem.
Recreating the DooNetwork device gave it a housecode of ^1
Once again thank you for your help.
PS: Please note that I did NOT give ANY of my devices a house code! They all get generated by the software!
