RFXMeter communication failure
Antoon
Post by Antoon »
Bert, I get almost every day communnication error on the RFXmeter.
In the charts I also missing 3 or 4 hours of data.
Distance from the RFXMeter to the RFX LAN receiver is about 10 meter.
Is there something that can be optimized?
- Antoon
<h6>HomeSeer 2.3.0.60
ACTTI103,BLAB8SS,BLMediaPlayer,DooNetwork,BLEditor,BLOccupied,DooMotion,ActiveBackup Plugin, BLGarbage,BLRandom,BLSpeecht,NetCAM,pjcOutlook, YACSeer,DooCPU Monitor, HSTouch Server,RFXCOM, BLRfid,SMS Connector</h6>
b_weijenberg
Post by b_weijenberg »
try this:
Open the RFXMeter enclosure and disconnect the yellow antenna wire at the bottom side of the RFXMeter. Leave the wire connected at the top side (close to the LED)
Drill a small hole next to the LED hole in the top cover so that the antenna wire can be positioned straight upwards.
Antoon
Post by Antoon »
Thanks Bert, I will try this.
- Antoon
<h6>
