Hello
I need to Use Xanura & X10 modules ( Mixed setup ) Can CM15 work with both? in this case can i use the status option of A10?
Also can I install ss13 or Easy Touch 35 remotes with Xanura Diax for example, Can I use X10 detectors with HCB controllers?
BR
Hany
A10 & X10 setup
A10 & X10 setup
yes you can, x-10 and a10 are the same.
Years ago the output of X-10 was lower then A10, but these days they are both around 5 volts.
