Ziggo Cable Internet 50MB down 5 up
Ziggo just updated the website with the new cable speeds and the Docsis 3.0 modem.
I think I will trade one traditional ADSL line in for this cable type.
Which one it will be? Xs4all or Telfort?
Any one some experiance with the new speeds and Docsis 3.0 modem?
I'm waiting for my new modem...
They have none in stock at the moment.
The max download speed of this modem will be 250mb in the future.
Yes later this year Ziggo will go up to 80 or 100!
Is the cable modem any good or did you set it to bridged?
If bridged any problems with setting up the voip on another router?
I have connected to Fritzbox..no problem at all
Also the phone part from ziggo modem is connected to Fritzbox.
I hope that the Fritzbox 7270 can handle 50Mb.
I know that the Wan port can't do that (Adsl2)
Since I'm using one of the Lan ports as wan 50 mb should not be a problem..(i hope)
else i I will upgrade it the the new fritz box 7370..later this year availible.
I think it will work, lets see
so you have set your Ziggo modem to bridge?
You can't access the modem
Modem is installed as bridge
It will always forward the Internet Ip to the first connected device.
Funny thing is when you connect a single machine to the modem and install Vmware on this machine...all the VM's will get a real Ip address.
Ok that is right it's gets the real IPNR does not matter if that is a Computer. Same here with ADSL if I connect directly a laptop to the modem.
Question: how is the voip handled with ziggo then, a seperate voipmodem?
Nope same modem with two pstn outputs.
In other topics I red you connected those pstn outputs with the Fritzbox?
yep..some problems with connection...
if used correct cables all works well.
To save power and reduce the number of power adapters:
Ziggo modem, Fritzbox, Lava Device server,Belkin USB are connected to one 12 volt adapter of 3,8A
usage is 17 watt
usage is 17 watt
OK but on which port of the Fritzbox did you connect the pstn output from the ziggo modem?
PSTN from Ziggo modem is connected to DSL/Tel with the special Y-cable delivered with Fritzbox
Available output on the FritzBox
2 x PSTN out
1 X ISDN S0 out
4 Lan (when using as rout without ADSL you can configure one of the lan ports as WAN port.)
1 Wan (ADSL 2)
2 x PSTN out
1 X ISDN S0 out
1 Wan (ADSL 2)
OK now I get it
Thanks
Don't forget the Fritzbox plugin for Homeseer..
