Merten / Popp
- Willem4ever
- Global Moderator
Merten / Popp
After installing a Merten CONNECT 507001 I found some differences between ZWAVE modules. Popp doesn't do associations, MERTEN does. The Merten also allows you to send configuration parameters, Popp doesn't. I think it would be a good idea to share some of this info for the various DUT's (Device Under Test) we currently have.
Merten / Popp
4,7 and 8 are Popp including ASSOCIATION
[img]uploaded/Chak/2009717194350_Zwave-chak.png[/img]
Merten / Popp
after Node optimization option..
[img]uploaded/Chak/2009717215631_zwave2.png[/img]
Merten / Popp
The sun screen module from Popp does has the possibility to send a configuration to it. I have done it to stop the extra needed button to stop the screen. (see manual) I've done this by using the configuration within HS to send the config to the module.
Merten / Popp
@mgizmo
How have you done that in HS?
HS zwave interface is a bit *&^@$*&!$@*#
- Willem4ever
- Global Moderator
Merten / Popp
This option appears under the device itself, click configure and you will see an option set parameter number.
Merten / Popp
edit the device within the overview of all your devices (status page) and click on the "configure" button. Choose parameter "1" in the dropdown list and "0" in the configuration value list. Hit the "set" button. The setting has now been activated.
