Only................... I don not know any more how I did it, but it can be working !!
Included Popp wireless wall switch in HS
After a lot of trial and error I finaly managed to include the Popp wireless wall switch in HS and associated it with a module.
Well well........ That's good News!
Still 3 to go but this time please make some notes for us how you did it!
Sure will
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ezHome</i>
<br />Well well........ That's good News!
I am not sure what Popp controller you are using but:
As far as I know Popp = Duwi except the name.
From Micasaverde forum ( http://forum.micasaverde.com/index.php? ... sg4965#new )
"According to Duwi's engineers, their remotes do *not* support the Z-Wave scene controller or scene transfer commands. So they're not technically Z-Wave handheld remotes, because those commands are mandatory for a remote since that's the only way to transfer scenes into them. The Duwi uses their own proprietary closed system, I was told, where you have to build the scenes within the remote. So, you can include the remote into Vera's Z-Wave network, so the Duwi can see and talk to all the Z-Wave devices, but you can't create scenes in Vera and transfer them to the Duwi, or use the Duwi to trigger scenes in Vera, because it doesn't support Z-Wave scenes."
William,
Can you see what the role is from Homeseer?
I think this is what you did:
Adding the nodes into the remote wall switch (this way it becomes a primary controller)
Copy the nodes to Homeseer so Homeseer is a secondary controller now.
I also tried this workaround into Vera and this works, so I can control the nodes with the wireless wall switch and I can see them in Vera and control them.
Vera's role now is secondary controller instead of primary.
What can't be done is activate a scene or an event, same as in Homeseer.
I have also a topic about this switch on HS forum.
It will be great if events can be controlled.
Willem did you try event triggering?
I have given up trying to get my Duwi ZW FB 10 remote working with a master.
So I have connected it to my House Controls network, and made the associations directly between remote and dimmers/switch's. That works fine. Both Duwi and House Control controls the devices.
But I want my remotes to activate scenes. So no more Duwi remotes for me.
I think, I have had a Innovus Z-ring working with a HomeSeer demo. So I guess QEES ring will to. http://viewer.zmags.com/publication/b8e ... b8efbb78/1 . I had some trouble but unfortunately I didn't make notes, and it was a while ago.
Willem-Jan,
That should mean that my AEON is secundary now, and that I can not add any nodes any more with the AEON? I have to give this a try this week. I think what I did from HS is making a copy of the AEON to the Duwi-switch. This is the dicription of HS:
<i>Use to add new nodes or remove nodes from a secondary Z-Wave controller. This is done by copying the node information from your primary HomeSeer Z-Wave controller into your secondary controller.
</i>.
For Chak:
I also have written my info on the topic you started on the HS-forum, maybe they can help us any further. And no, I can not trigger an event by actuating the Duwi, I believe this is not possible with any transmitter like the Duwi, somewhere on the HS-forum I saw a topic where Rick stated that only Wayn-Dalton transmitters or nodes will report status changes to HS without polling and so on. I have 2 ACT-transmitters over here, they have the same problem, you will never see a status change of them, they always report status 'off'. Maybe because transmitters do not control a load, but only send commands to controllers/nodes. But there is always a work-around to trigger a event by menas off a wall-transmitter: let it switch a cheap node and fire a event on the status change of that node.
<br />William,
</i>.
For Chak:
<br />William,
If you controllers support SUC/SIS, secondary controllers can add nodes.
My Innovus SmoothRemotes can add nodes to my network, where Innovus House Control is primary.
O.k., then I have to find out wether the AEON supports this, may Ezhome can give a answere to this?
Edit:
Already found it: Based on Zensys 5.02 protocol (40kbps bandwidth, SUC/SIS)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mhn</i>
<br />If you controllers support SUC/SIS, secondary controllers can add nodes.
Edit:
Yes you can add nodes to your network, the Aeon-Labs supports SUC/SIS.
The Homeseer description is the other way arround, this would mean that Homeseer/Aeon-Labs still is prim and the Popp is secondary.
What in my case is that the Popp is prim now and Vera/Aeon-Labs is secondary now. Due to the SUC/SIS I am still able to add nodes to the network with my Aeon-Labs.
Let's make z-wave EZ
That's also what I tought, the AEON is still primary, ther is also a other possiblity in HS and then it will become secundary, so use these options with <b><font color="red">caution</font id="red"></b>!
<br />Yes you can add nodes to your network, the Aeon-Labs supports SUC/SIS.
Starting scenes can be done by these kind of devices (at least in Vera, in Homeseer I don't know for sure), the Merten Impulsdrukker can do this by programing the 2 or 4 buttons and adding a scene to it like you can with a remote control.
These devices are actualy simple remote controls with 2 or 4 buttons.
This is how I did it:
http://board.homeseer.com/showthread.ph ... post882460
Just programmed another two wall-switches without any problem.
Willem,
thats good News.
Can you now trigger events?
thats good News.
