I have a few assembled and unassembled RFXio Digital I/O sets available. Send me a PM if you want more technical and pricing details.
The RFXio is supported by the beta plug-in version 14.0.0.18 which is available for download on request.
The RFXio Digital I/O interface has up to 8 Input-Output lines. Each line can be configured to be used as an Output using a relay contact or to be used as an Input using the opto-coupler.
The 1 port RFXCOM LAN interface has 2 I/O lines available.
The 2 port RFXCOM LAN and WLAN interfaces have 8 I/O lines available.
The RFXio Digital I/O interface must be connected to a RFXCOM Ethernet interface with a 14 wire ribbon cable.
Important: The 14 wire ribbon cable must be soldered to the RFXCOM Ethernet interface by a person that has soldering skills.
Bert
Limited number RFXio Digital I/O available
- b_weijenberg
Hi Bert,
I'm interested, but cannot send you a PM, please PM me about this.
thanx
Arjen
thanx
Arjen
Bert,
Can you send me the details so I can think if this would be interesting for me? Also cannot send pm yet.
Jan-Willem
Jan-Willem
- Willem4ever
- Global Moderator
Bert, are the "white" components the relays ?? they seem (very) small can your share he specifications with us . Thanks ..
- b_weijenberg
Recently I am in possession of an interface RFXio
Its working fine
The only thing not working is a short pulse on the input that is not seen
Because the input is polt.
This was solved by making a puls extender.
Now it works even with a very fast pulse, example off the doorbell.
http://www.domotica.famschenk.eu/RFXio_Timer.html
Ps.you can also use this for the IPPower
Ed
Its working fine
Ed
From the diagram you don't use the reset button and the 0,01uF, right?
Trigger is the doorbell button and output is going directly to the input of the RFXio.
** edwin **
** edwin **
Hello Edwin,
Thats correct,
If you want to use also your existing doorbell then you must use a relay to the input of the timer.
Ed
Thats correct,
Ed
