Popp/Duwi dimmer nervous light
Alexander
Post by Alexander »
After contacting ezHome i got the message that my "problem" wasn't known. I've to say that these products works very good. Better than Xanura!
What is the "problem": My lights are flickering sometimes. I promised to contact ezHome when it happens often and write the details down (dim level/time/etc.).
But this evening a thing happened and i was wondering if somebody did noticed this by his own setting: At exactly 19.00 hour my lights did flicker again but in a interval like it was a process on the electricity network.
Does somebody have the problem? Maybe at an interval that is exactly by the hour? BTW: Dimlevel was at 50% and it are normal lightbulbs connected to the dimmer.
<b>Current findings (only in-wall Duwi Dimmers)</b>
Rotterdam - Alexander:
- 19:00 t 19:02
- 23:00 t 23:02
- 01:00
- 02:00
Utrecht - Kaandorp:
- 12:15
- 19:00
- 20:00
? - William.abo:
- 23:00
EzHome
Post by EzHome »
Seems a bit like this http://www.domoticaforum.eu/topic.asp?TOPIC_ID=3268
Are there any other users with this symptom so I can contact Duwi and try to find out what it could be and how this can be solved.
snowboarder
Post by snowboarder »
i have the same with one popp/duwi dimmer connected to two spots
www.myhomecontrol.nl
Alexander
Post by Alexander »
And now i know for sure: Exactly 19:00 hour this evening same happens. Im in Rotterdam area.
Alexander
EzHome
Post by EzHome »
@snowboarder: What area are you in if I may ask?
kaandorp
Post by kaandorp »
I have exactly the same issue and was about to mail ezHome when I saw this topic. I'm not 100% sure, but it seems that the flickering is in sync on all lights that are on at that specific moment. It looks like it takes about 5 to 10 seconds and then it stops again. I'll keep an eye on the clock when it happens and will report in this topic. I'm living in Woerden (near Utrecht) by the way.
UPDATE: I just saw it again at exactly 12:15 (4 nov 2009)
Alexander
Post by Alexander »
@ehHome: Can you contact Duwi with this current findings? I'm very interested if they have a solution like a DIN filter.
Alexander
snowboarder
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ezHome</i>
<br />@snowboarder: What area are you in if I may ask?
groningen
Alexander
Post by Alexander »
@snowboarder: any reference to the time&date?
Alexander
EzHome
Post by EzHome »
Who has the same in-wall dimmer and a plug-in module from Duwi/Popp, this to make sure if it is just the in-wall or also the plug-in device what has this issue.
Let's make z-wave EZ
snowboarder
I have one in-wall dimmer and three plug-in dimmers
i only see it with the in-wall dimmer not the plug-in dimmers
Marcel
<br />Who has the same in-wall dimmer and a plug-in module from Duwi/Popp, this to make sure if it is just the in-wall or also the plug-in device what has this issue.
EzHome
Post by EzHome »
Okay this makes is more clear to me, I'll contact Duwi with this information and keep you all posted as soon as I have some info.
I was wondering who snowboarder was, so had to ask for it :-)
greatings to you Marcel.
kaandorp
Post by kaandorp »
I only have in-wall dimmers. I noticed it again today at 19:00 and 20:00. It looks like it only happens during whole or half hours.
Michael
William.abbo
Post by William.abbo »
Have same problem with the in-wall dimmer from Duwi, always round 23:00 o'clock and ONLY the Duwi in-wall dimmers.
Alexander
Post by Alexander »
@William: What's your location?
Alexander
Return to “Z-Wave Forum”
