so what are the experiences?
So I am wondering. Has anyone used the KAKU devices and what are the experiences? I am thinking of switching to this system a bit and maybe move away from Xanura. Since I use homeseer it doesn't matter anyway and I can different protocols around the house. Xanura is nice, but also expensive and I seem to have still problems with noise on the line.
The system is cheap compared to the alternatives, but how well does it work?
Will let you know when I get my package of goodies
So far I've used HE and Oregon for sensors, I'll ad a couple of KAKU for that and I'll experiment with some in wall dimmerswitches as well.
I will use this to switch lights in hallway and kitchen and see how well it performs, I'd like 2 switch to Z-wave, but prices are keeping me back.
It'll be one way communication for now.
I use Kaku (15 devices), plugwise (10 devices) and Oregon controlled by RFXCOM/Homeseer. This works now for more then half a year without real problems. I let the kaku do direct control (so when homeseer is down the basic things still work). Homeseer is used for advanced things. For me it works very good!
- Jeroen Bartels
I have been using Homeseer/RFXcom and lot's of Kaku too. Works fine for me, especially the dimmers that can be set on a certain brightness.
**Jeroen**
**Jeroen**
Re: so what are the experiences?
@Jaybee
How do you set the kaku devices to a specified dim level with rfxcom? i.e. how did you specify the kaku device in rfxcom, i used AC module according to manual.
** edwin **
- b_weijenberg
create an AC DIMMER for a dimable KAKU!
I use a AGDR-300 (the one without adress wheel) and when i use AC DIMMER the device does not respond but i do have a dim preset scale
When i use the ARC DIMMER the module responds but i lost the dim preset scale?
It would be nice if i was able to switch the module via HS and make a choice in the dim level so i could switch the light on at night at 30% and during the day at 100%
** edwin **
- b_weijenberg
did you reset the AGDR module and programmed the unit again using the AC DIMMER device??
nop. this was a non-working device that i sent to customer service and got it working back. Until now i controlled it with a kakuYCT-102 remote and a few days ago i tried to control it via rfxcom.
** edwin **
This works now for more then half a year without real problems. I let the kaku do direct control (so when homeseer is down the basic things still work)?
Pass your Testking microsoft answers and in first try by using our guaranteed and best quality Testking istqb syllabus If you are looking for fast success in regiscollege
