See attached pictures
(click on pictures, to see full size)
this runs on a small 800x600 touch screen in my living room.
The buttons at the bottom are the most interesting.
There are more buttons, than fit on the screen.
You just slide your finger over the buttons, like you would on an iphone, to bring the desired button into view.
Marcel
netremote thermostat user interface...
- thermostat 1.jpg (109.53 KiB) Viewed 6207 times
- thermostat 2.jpg (115.6 KiB) Viewed 6207 times
- thermostat 3.jpg (70.34 KiB) Viewed 6207 times
- thermostat 4.jpg (93.83 KiB) Viewed 6207 times
- thermostat 5.jpg (87.92 KiB) Viewed 6207 times
Re: netremote thermostat user interface...
some more pictures
- thermostat 6.jpg (112.08 KiB) Viewed 6206 times
- thermostat 7.jpg (128.43 KiB) Viewed 6206 times
- thermostat 8.jpg (130.38 KiB) Viewed 6206 times
- thermostat 9.jpg (133.67 KiB) Viewed 6206 times
- thermostat 10.jpg (133.41 KiB) Viewed 6206 times
Looks good Marcel.
IS this build in HStouch?
no Enver...
See title of the post
: it's done using netremote. (and girder as back end)
Marcel
Marcel
Netremote...very clean and functional.
In the living room you have for the lights sliders, why no labels?
left slider : dim level of all lights in the living room. I don't want a slider per light. so all my X10 dimmers in one room are set to the same address..In the living room you have for the lights sliders, why no labels?
middle 3 sliders : RGB led strip #1 top
right 3 sliders : RGB led strip #2 bottom
(see domoticaforum.eu/viewtopic.php?f=33& ... mp;start=0)
Marcel
Better RGB control is also on my list for this year..
