Homeseer 2.4.0.11 beschikbaar
rwitkamp
Post by rwitkamp »
WHAT WAS FIXED OR CHANGED IN THIS RELEASE
2.4.0.11 - If Rescan (Full) is used, it now forces the retrieval of the Z-Wave command classes from the node.
Fixed an error in the calculation of sunset and sunrise times for timezones having offsets that were not whole hours - e.g. Newfoundland's offset from GMT is 3.5 hours.
2.4.0.10 - Several changes with the handling of commands sent to multiple Z-Wave devices at once, including scene commands, as it was possible previously for an error reaching a node to cancel the send in the middle of the operation. (Thanks to Bob @ Cooper Wiring for finding that one!)
Added LED control and LoadSense enable/disable control for ZRR150 in device properties.
All Deprecated API warnings can be disabled from the "Disable obsolete API procedure warning messages" setting in setup.
Fixed Z-Wave startup to always leave the Z-Troller at 40K mode
2.4.0.8 - Fixed issues with Multicast Z-Wave commands.
2.4.0.7 - Fixed an issue with values from Z-Wave sensors containing negative numbers not being handled correctly.
Noel
Re: Homeseer 2.4.0.11 beschikbaar
Post by Noel »
Ik had gisteren al de update gedaan.
Tot nu nog geen probleem gezien.
Moest wel al mijn Z-wave devices her scannen.
Alexander
Post by Alexander »
ik zie geen reden om te upgraden. Waarom doen velen dat standaard? De changelog geeft mij aan dat er niets veranderd is dat mij raakt.
Alexander
Ik heb de update ook nog niet gedaan. Rescan van zwave modules is leuk maar erg lastig als het om batterij gevoede versies gaat. Zoals danfoss en puls drukkers van duwi
