Guruplug
Snelvuur
Guruplug
Post by Snelvuur »
Mean & Green
Drawing under 5 Watts of power, this little palm-sized powerhouse can handle all your biggest tasks while still saving about 96% on energy costs when compared to the average 175 Watt desktop computer.
Limitless
You can customize your Plug to work in almost any industry - Home Automation, Security/Survellance, Medical Monitoring, Industrial Automation, Smart Grid Electrical, Mesh and Grid Computing.
Get Connected
You can never have enough storage, not to mention fast access to all that data... That's why we have provided Wi-Fi, Bluetooth, Gigabit Ethernet, USB 2.O and eSATA connection options to the Server line of products. Go ahead give us what you got, we can take it.
Package Contents:
* GuruPlug Server - PLUS
* (2x Gb Ethernet, 2 x USB 2.0, 1x eSATA @ 3Gb/s SATAII, 1x MicroSD Slot)
* Interchangeable US, UK, or Euro Power Adapter
* USB Cable
* Ethernet (cat 5) Cable
* CD Containing Software and Documentations
http://www.globalscaletechnologies.com/
can be a nice toy, perhaps for in the car with gps? dont know , but its small and low powered...
j.hoekstra
Re: Guruplug
Post by j.hoekstra »
Ah sheevaplug v2.
Wonder how good plugwise, bluetooth and other USB-adapters work via an USB-hub....
Would like something like this for domotiga.
Post-IT
Re: Guruplug
Post by Post-IT »
I don't get this... why not include PoE and lose the 230V plug.
It would be an ultimate platform to control my touchscreens... if HStouch would run on it.
Re: Guruplug
I think they are a bit short in their information.
What is this precicly, what can it replace and give some examples?
I don't get the feeling now that i do need one. It's more like 'what is this and i don't need this thinggy whatsosever'
j.hoekstra
Re: Guruplug
It's meant to provide a cheap and lightweight server of sorts. This is just on incarnation of the kirkwood-platrform of ARM. On the other side of the big pond companies are offering these with an online storage option to share files stored on this plug.
People which are using NSLU's can use these as a replacement.
I'm contemplating one to use domotiga on it.
Re: Guruplug
Oke, but how do i control this server? Can't attach a screen to it so it must be remote. And the OS, is this limited to linux or can you also boot an OS from an attached disk? Will HS run on this? i suppose not.
j.hoekstra
Re: Guruplug
You could control it via the std remote tools that linux provides, ssh, http and others depending on your configuration.
Standard there will be Linux on it, the only possibility to get something remotely like windows on it would be windows CE or alike. If you can install HS on that, you should be able to get something really low-power.
Because it isn't x86 it's hard to get windows on it, if at all possible.
For me it's ideal, if you're stuck on windows, it won't be for you...
Pieterpaul
Re: Guruplug
Post by Pieterpaul »
BTW: there is also a version with HDMI output...
Bart
Re: Guruplug
Post by Bart »
There's an action on Samenkopen: http://www.samenkopen.net/action/734595
