Page 1 of 2
Sun screen with zwave
Posted: Fri Mar 12, 2010 5:39 pm
by Wim2008
I like to buy a new sun screen this summer.
Has someone some information/experience about zwave and a sun screen, that can controlled with homeseer with sensors like wind, rain and sun?
B.R. Wim :) :wink:
Re: Sun screen with zwave
Posted: Wed May 19, 2010 8:50 pm
by Wim2008
Is there a person who can tell something about a new sunscreen for outside which will be working with zwave?
Somfy has several screens with motors. Which one must I choose to connect with a zwave connector.
I like also to control this sunscreen with events in homeseer.
Best regards Wim :) :wink:
Posted: Fri May 21, 2010 10:32 am
by Edwin2008
I think your best bet is to order a sunscreen without remote control that is being operated with a wall switch.
This way you will get a bunch of wires on which you can connect a solution like zwave, marmitek, kaku. I don't think that you will find another solution that can communicate directly to the somfy wireless solution and that is also homeseer compatible.
Posted: Fri May 21, 2010 4:26 pm
by Jeroen Bartels
I also bought 2 sunscreens without wireless capabilities. instead of the wallswitch I connected a KAKU SUN-500 module. Works fine and is future proof.
Posted: Fri May 21, 2010 7:21 pm
by Wim2008
Thanks for your informations.
I will look for a sunscreen with continue power and with a wall switch.
Posted: Fri May 21, 2010 8:24 pm
by TANE
All my screens are zwave controlled..just normal screens.
For some of them I have even no switch inside
Duwi Zwave screen controle is outside built in a IP 65 box.
For wind and rain the I'm going to use oreagon sensors.
For the sun still looking for a good klx sensor.
Posted: Fri May 21, 2010 8:41 pm
by Wim2008
And which mark/type of sunscreens did you buy, Enver ?
All with continue power?
B.R. Wim :) :wink:
Posted: Fri May 21, 2010 9:07 pm
by TANE
This are screens made by company GUN.
What do you mean with continue power?
Zwave switch will turn of the power after 2 minuts
Posted: Fri May 21, 2010 9:14 pm
by Wim2008
I heard that the motors used inside the sunscreens which can be a 230 V pulse motor or a motor with continue 230 Voltage.
B.R. Wim :) :wink:
Posted: Fri May 21, 2010 11:39 pm
by abl
That's very interesting, this two minute story. I have several sun screens around my house, and I have attached all to Merten switches. Most of them work perfectly, but two (both multiple screens switched together) do function once and after two minutes close by themselves. Seems to me that this could be related to the power down after two minutes.
I had contact with a z-wave specialist from Merten and he advised me to buy some Merten relais instead of the currently installed relais.
Now I'm not so sure that it would be related to the relais, but maybe two different motors are being used...
Posted: Fri May 21, 2010 11:44 pm
by Wim2008
And what a kind (Mark/type) sunscreens you have ?
B.R. Wim :) :wink:
Posted: Sat May 22, 2010 12:13 am
by abl
These are screens of Verano, not sure which motor is used. Perhaps I will go to the distributor tomorrow and will ask him (should I ask whether this is a continuous one or should I ask something else?)...
Posted: Sat May 22, 2010 7:55 am
by Wim2008
It should be a motor with puls or continue power. I understand that there is for puls also 230V and lower voltages.
Where did you buy the sunscreen?
B.R. Wim :) :wink:
Posted: Sat May 22, 2010 9:38 am
by abl
I did buy them in Belgium (www.verano.be), but I can't find any details on the site, just general information...
Posted: Sat May 22, 2010 11:24 am
by Wim2008
The details are always difficult to see by sunscreens. It looks like they don't like to share technical information.
B.R. Wim :) :wink:
