i have chanced something in my rfxcom reciever. prior to this when i turned on rfrececiver on the computer, the lan rfxcom receiver unloaded information from the past in the program, but now he only passes live received information to the program.
does anyone knows which setting is responsible for this chance ?
labium
*** basic parameters
Hardware: Ethernet TPI
IP addr 10.10.10.10, gateway 10.10.10.1,netmask 255.255.255.0
*** Security
Telnet Setup is enabled
TFTP Download is enabled
Port 77FEh is enabled
ECHO is disabled
Enhanced Password is disabled
Port 77F0h is enabled
*** Channel 1
Baudrate 38400, I/F Mode 4C, Flow 00
Port 10001
Connect Mode : C0
Send '+++' in Modem Mode enabled
Show IP addr after 'RING' enabled
Auto increment source port disabled
Remote IP Adr: --- none ---, Port 00000
Disconn Mode : 00
Flush Mode : F7
Pack Cntrl : 00
*** Expert
TCP Keepalive : 45s
ARP cache timeout: 600s
Monitor Mode @ bootup : enabled
MTU Size: 1400
Alternate MAC: disabled
Ethernet connection type: auto-negotiate
Memory rfxcom receiver
- b_weijenberg
Re: memory rfxcom receiver
This is flush mode.
It is advised to use this mode because the receive buffer in the LAN controller is not that big and when the buffer becomes full the last packet will be truncated.
For detailes see the Xport guide delivered on the RFXCOM CD or on line at the Lantronix site.
