I use ubuntu. On my server i have a gui-less ubuntu lamp server installation which I administer through ssh or X-forwarding when i need a gui. (eg: ssh -X root@myserverip). All clients run the latest ubuntu. In order to get vdpau up and running you need to install a recent nvidia driver and the vdpau library package from synaptic. You should probably be satisfied with the current mythbuntu release, it incorporates VDPAU and the installation/configuration is clear and concise.drmacchi wrote:luria please, could you explain how to set an ion device to reproduce video HD from a Mythtv server ? I can not image how to play a hd movie without OS and player.
Could you give the list of what is necessary (sw i mean)
Your setup is really interesting !
Thanks a lot.
I, however, need to compile my own since i have several patches that fix some things I regard as issues (norwegian letters in subtitling being one of them).
I have a ugly bash-script (i'm no programmer) that automagically downloads, compiles and installs mythtv for me. You can select which version (bleeding edge trunk, stable fixes or any version number from the timeline, and if you want a client or server install. Unfortunately it is partly in norwegian, but it should be easily readable. A simple
apt-get build-dep mythbuntu
#!/bin/bash
function lastned {
echo "Henter $1"
while ! ( eval "svn $download/$1 2>nedlastingsfeil.txt" )
do
if [ "$unatt" == "no" ]
then
read -s -n1 -p "nedlasting av $1 feilet: nytt forsoek (y/n)" keypress
if [ "$keypress" == "n" ]; then exit 1; fi
echo "(y) Proever paa nytt"
else
echo "Feilet! svn $download/$1"
exit 1
fi
done
if [ -e "nedlastingsfeil.txt" ]
then
rm "nedlastingsfeil.txt"
fi
function kompiler {
cd ~/$1__*
echo "Kompilerer $1" `date +%H:%M`
if [ -e "~/$1_gammel/kompileringstid" ]
then
cat ~/$1_gammel/kompileringstid
fi
SECONDS=0
if ! ( eval "make -j3 -s 1>/dev/null 2>make_errors.txt" )
then
echo "$1 kompileringsfeil"
tail make_errors.txt
exit 1
else
echo "$1 kompilert."
tid=`echo $(((SECONDS/60)/60)) timer $((SECONDS/60)) minutter $((SECONDS%60)) sekunder`
echo "$tid" >>kompileringstid
touch "Kompileringstid $tid"
fi
function avinstaller {
cd ~
if [ -d myth_gammel ]
then
cd myth_gammel/$1__*
if [ -f "$1 installert!" ]
then
echo
echo "Avinstallerer $1"
if ! ( eval "make uninstall 1>/dev/null 2>uninstall_error.txt" )
then
echo "Avinstallering av $1 feilet"
else
echo "Avinstallerte $1."
fi
else
echo "Ingen fil funnet i $1 katalogen."
fi
fi
function installer {
cd ~
cd $1__*
if ! ( eval "make install 1>/dev/null 2>install_error.txt" )
then
echo "Installering feilet!"
tail install_error.txt
exit 1
else
echo "$1 installert."
touch "$1 installert!"
fi
type="frontend"
versjon="fixes"
unatt="yes"
stopp="installer"
usage () {
echo "
Usage: `basename` [-b] [-t] [-p] [-h patch:kompiler] [-s version]
-b (b)ackend [default frontend/klient]
-t Latest (t)runk-versjon [default stable fixes version]
-p (p)rompt or [use defaults]
-h patch|kompiler Only patch|only compile [default install everything]
[ "$#" -lt 1 ] && usage && exit -1
while getopts "btph:s:" Option; do
case "$Option" in
b) type="backend" ;;
t) versjon="trunk" ;;
p) unatt="no" ;;
h) stopp="$OPTARG" ;;
s) versjon="$OPTARG" ;;
*) usage; exit -1 ;;
esac
done
shift $(( $OPTIND - 1 ))
cd "$HOME"
temp=$(ls -d mythtv__*)
gmlversjon=${temp: (-5)}
echo "Siste installerte versjon er :" $gmlversjon
siste=$(svn info -r head http://svn.mythtv.org/svn/trunk/ |grep Revis)
sistver=${siste: -5}
echo "Latest trunk version is:" $sistver
case "$type" in
backend)
echo -n "./configure --enable-proc-opt \
--enable-audio-alsa \
--disable-joystick-menu \
--disable-audio-jack \
--disable-directfb \
--disable-lirc \
--enable-v4l \
--enable-ivtv \
--disable-firewire \
--enable-dvb \
--dvb-path=/usr/src/linux-headers-`uname -r`/include \
--disable-opengl-video \
--disable-xvmc \
--disable-hdhomerun \
--disable-x11 \
--disable-hdpvr \
--disable-opengl-vsync \
--disable-iptv" > mythtv.conf
chmod 777 mythtv.conf
frontend)
--enable-lirc \
--enable-v4l \
--disable-ivtv \
--disable-dvb \
--enable-opengl-video \
--disable-xvmc \
--disable-xvmc-vld \
--disable-xvmc-pro \
--enable-opengl-vsync \
--disable-iptv " > mythtv.conf
if grep -i -q "nvidia" "/etc/X11/xorg.conf"
then
echo "--enable-vdpau" >> mythtv.conf
fi
N=$NAME
echo "Bruk: $N {-backend|-frontend} [svn version] [-patch|-install]" >&2
exit 1
esac
if [ "$versjon" == "trunk" ]
then
download="co http://svn.mythtv.org/svn/trunk/"
else
if [ "$versjon" == "fixes" ]
then
download="co http://svn.mythtv.org/svn/branches/release-0-23-fixes/"
else
download="co -r $versjon http://svn.mythtv.org/svn/trunk/"
fi
fi
echo "Velger $versjon"
patchdir="patcher"
then
read -s -n1 -p "oppdater.sh $1 $versjon $inst OK? (y/n)" keypress
then
exit 1
fi
svar="patcher"
echo
echo -n "Which subdirectory contains patches? [$svar]"
read patchdir
if [ -z "$patchdir" ]
then
patchdir=$svar
fi
echo $patchdir
fi
if [ -d myth_gammel ] # Remove, if exists.
then
echo
echo -n "Remove old"
rm -R myth_gammel
fi
##Foerste gang kjoeres
if [ -d mythtv__* ]
then
echo
echo -n "Make newfolder for myth_gammel"
mkdir myth_gammel/
mv mythtv__* myth_gammel/
mv mythplugins__* myth_gammel
mv myththemes__* myth_gammel/
fi
########Last ned
echo
echo "Downloading $versjon"
lastned mythtv
lastned mythplugins
lastned myththemes
#####Rydd opp
echo
echo "Downloaded $versjon"
mv mythtv mythtv__$versjon
mv mythplugins mythplugins__$versjon
mv myththemes myththemes__$versjon
####Legg inn konf-filer
cd ~
mv mythtv.conf ~/mythtv__*/
cd mythtv__*
./mythtv.conf > current.config
cd ~
cd mythplugins__*
echo "./configure \
--disable-mythflix \
--disable-mythmovie " > mythtv.conf
cd ~
cd myththemes__*
./configure
cd ~
echo
echo -n "Moving configuration files"
####Patch mythtv
if [ -n "$patchdir" ]
then
for file in $patchdir/*
do
if [ -e "$file" ]
then
cd mythtv__*
echo
echo -n "Patcher myth med $file"
patch -p3 < "../$file" >> patchlogg.txt
cd ..
else
echo "No (more) files in $patchdir"
fi
done
cd ~/mythtv__*
if [ -e "patchlogg.txt" ]
then
if grep -i -q "FAILED" "patchlogg.txt"
then
read -s -n1 -p "Patching failed! Continue (y/n) ? " keypress
then
exit 1
fi
fi
fi
else
echo
echo "No patching."
fi
echo
if [ "$stopp" == "patch" ]
then
exit 0
fi
kompiler mythtv
if [ "$stopp" != "installer" ]
then
exit 1
fi
###Stopp mythbackend/frontend
if ps -C mythbackend > /dev/null
then
echo
echo "Stopper mythbackend"
/etc/init.d/mythtv-backend stop
fi
if ps -C mythfrontend > /dev/null
then
echo
echo "Stopper mythfrontend"
killall mythfrontend.start
fi
###Avinstaller gammel
avinstaller mythtv
avinstaller mythplugins
avinstaller myththemes
####Installer ny
installer mythtv
#Bare hvis frontend
kompiler mythplugins
if [ "$1" == "backend" ]
then
### Fikse mythweb for backend
cd /var/www/
rm mythweb
ln -s ~/mythplugins__*/mythweb mythweb
chown -R www-data mythweb/data
chmod -R 775 mythweb
cd ~
fi
cd mythtv__*
echo "Brukte $tid"
cd ~
if [ "$type" == "backend" ]
then
/etc/init.d/mythtv-backend start
exit 0
fi
if [ "$type" == "frontend" ]
then
#ln -s /mnt/extras/.mythtv/mainmenu.xml ~/.mythtv/mainmenu.xml
#ln -s /mnt/extras/.mythtv/annet.xml ~/.mythtv/annet.xml
reboot
fi
exit 0
A note: As you can see, this installs a common image for all clients. However, using several images for different hardware setups is easy. Just copy your original image to a new location within the nfs mount, make a new tftboot subdirectory, copy the files and change the /tftpboot/pxelinux.cfg/default to point to the new nfs location. Finally set your dhcp server to distribute this directory to the other frontend based on it's mac-address. Remember that you can chroot into these images form the server and do maintenance, updates and so on without even powering on the clients. This makes it easy to keep everything WAF-compliant.
MythTV multiple diskless frontends HOWTO
1) First step is to get your backend and at least 1 frontend setup and configured.
There are so many guides with how to do this i can not go into the details in this howto.
2) On the Backend you will need to install some software packages.
dhcp3-server tftpd-hpa syslinux nfs-kernel-server initramfs-tools
other distros use your tool of choice.
Let also make some direcotry's we will need
mkdir -p /tftpboot/pxelinux.cfg
mkdir /nfsroot
cp /usr/lib/syslinux/pxelinux.0 /tftpboot
you can use it or we can install dhcpd here on the backend.
4)You need to add two things to the top of your dhcpd.conf once you have it set up for your
liking.
allow booting;
allow bootp;
One more change is at the end of your subnet declaration you should add...
filename "/pxelinux.0";
If your dhcpd is not on the same system as your backend you will need to add...
next-server xx.xx.xx.xx;
Add this before the filename "/pxelinux.0"; entry, and replace the xx with your backend IP
Your dhcpd.conf should look something like this.
allow booting;
allow bootp;
subnet 192.168.2.0 netmask 255.255.255.0 {
range 192.168.2.xxx 192.168.2.xxx;
option broadcast-address 192.168.2.255;
option routers 192.168.2.xxx;
option domain-name-servers 192.168.2.xxx;
5) You now need to install and configure a tftp server on you backend.
You will need to edit etc/default/tftp-hpa and make it look like this
#Defaults for tftpd-hpa
RUN_DAEMON="yes"
OPTIONS="-l -s /tftpboot"
now, start the tftp-hpa service:
/etc/init.d/tftp-hpa start
LABEL linux
KERNEL vmlinuz-2.6.15-23-686
APPEND root=/dev/nfs initrd=initrd.img-2.6.15-23-686 nfsroot=192.168.2.2:/nfsroot ip=dhcp rw
of your frontend machine.
6) Getting NFS setup
Modify /etc/exports on your backend and add...
/nfsroot 192.168.2.1/24(rw,no_root_squash,async)
Note we are mounting READ and WRITE, this is just initially to get things squared away. Once
you are happy with your setup you can change that back to ro,
Now issue exportfs -rv, that will update your NFS configuration.
7) Now we need to get an image of your working fronend to NFSROOT
You will issue these commands on the frontend and they will copy your installation to the
NFS server.
mount -tnfs -onolock 192.168.1.x:/nfsroot /mnt
cp -ax /. /mnt/.
cp -ax /dev/. /mnt/dev/.
THis WILL TAKE A WHILE as it is copying your complete image install to the NFSROOT.
This is real simple on the frontend issue...
Code:
mkinitramfs -o /root/initrd.img-2.6.20-16-generic
Of course change the name of the initrd file to match your existing one exactly.
This will drop the new one in roots home dir.
9) Now we will make a few modifications to your NFSROOT image to make it happy with net
booting.
On the backend edit /nfsroot/etc/initramfs-tools/initramfs.conf
Change to BOOT= flag to read BOOT=nfs
Now you do not want the system to bring up your network interfaces cause they are allrady up!
So edit /nfsroot/etc/network/interfaces and make it look like this...
# The primary network interface, commented out for NFS root
#auto eth0
#iface eth0 inet dhcp
iface eth0 inet manual
Now one last edit is /nfsroot/etc/fstab you need to make it mount / on NFS and change the
other default mounts to use tempfs. It should look something like this.
# /etc/fstab: static file system information.
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc defaults 0 0
/dev/nfs / nfs defaults 1 1
none /tmp tmpfs defaults 0 0
none /var/run tmpfs defaults 0 0
none /var/lock tmpfs defaults 0 0
none /var/tmp tmpfs defaults 0 0
/dev/hdc /media/cdrom0 udf,iso9660 user,noauto 0 0
10) Copy your kernel and initrd to your tftp server
Now copy the kernel from /boot on your frontend to /tftpboot on the backend.
Also copy your modified initrd from /root on your frontend to /tftpboot on your backend.
11) Thats it. Be sure your NFS/DHCPD/TFTP are running and reboot your frontend with PXE boot
from LAN. It should grab an IP and then your kernel from TFTP, then start booting your system
from NFS.
12) Now that things are working we need to make a small edit to the /nfsroot to make the front
end assign itself a dynamic hostname based on its MAC so that you can boot multiple frontends
and they each get their own configs in then DB.
Make a file in /etc/init.d/ called 00hosthack
#!/bin/bash
IPADDR=`/sbin/ifconfig eth0 | grep 'inet addr' | awk -F: '{ print $2 } ' | awk '{ print $1 }'`
FQHOST=`/sbin/ifconfig eth0 | grep 'inet addr' | awk -F: '{ print $2 } ' | awk '{ print $1 }'`
HOST=`host 169.237.30.111 | awk '{print $5}'`
echo [zj01] IP ADDRESS: $IPADDR FULLY QUALIFIED HOSTNAME: $FQHOST HOSTNAME: $HOST
echo $FQHOST > /proc/sys/kernel/hostname
Then chmod +x this file so it can execute.
This will make the machine change its hostname to its IP address during boot. This will make the backend
see each frontend as a differnt one and save all settings accordingly.
13) The way things are now, once booted you can ssh to your frontend and make any changes you want or
install new software. Once you get things exactly as you like change your exports file on the backend to make
the nfsroot READ ONLY by chaging rw to ro.
Good luck!
