Situation A: In IE8 the streaming picture of the IP Camera (Aviosys 9060L) on a WIN7-PC is flipped. 180 degrees opside down.
Situation B: On the same WIN7-PC the videostream from Sony IP Camera (SNC-RZ30P) is not flipped. This picture is oke.
Situation C: The videostream from the IP Camera (Aviosys 9060L) on a Win-XP PC is not flipped. This picture is oke.
Does anybody know the reason why the picture of the Aviosys IP-camera is flipped in situation A? Is it a Cameradriver problem? How to solve?
Thanks for help
Verkenner
IP camera FLIPped
Moderator: Esteban
IP camera FLIPped
Best regards, Verkenner
How easy ;-)
Well.....how can I tell ?
Put the mouse on the video-picture (in the browser) and right-click.
In the Rotate-option: choose Rotate=0
Thanks for Thinking.
Verkenner
Verkenner
Re: IP camera FLIPped
Good to hear that you fixed it.
a long time ago I had this problem with some "DivX" movies.
Some were okay, and some fliped!
My problem was that when a certain codec was used this only happened.
All I needed to do was to select the codec's menu, and select flip
It took me some time to find this.
