Irtrans Wifi
Irtrans Wifi
There is a new Irtrans Wifi version avilibile
Can be interesting for the locations where is no lan available.
Price is a bit higher than the lan version
LAN/Wifi 145/179 euro
http://www.irtrans.de/en/shop/wifi.php
Re: Irtrans Wifi
Interesting, I wonder if the reaction time is the same or if there's a slightly longer delay over wifi.
- Snelvuur
Re: Irtrans Wifi
Ofcourse its longer, you will notice this the most when your "zapping" through channels.
Re: Irtrans Wifi
Agreed, I'm just wondering if the difference is in the realm of 'barely noticeable' or 'damn that's significantly slower' as wifi can sometimes be quite snappy as well.
Re: Irtrans Wifi
The specs say 802.11 bgn, so in theory it could also be faster.
Re: Irtrans Wifi
Speed of IP is much faster that than IR can handle.
I'm sure it's fast.
I'm sure it's fast.
Re: Irtrans Wifi
Does anybody has experience with this wifi IRtrans and do you need any additional parts to get it going and how to get the plug-in. In the homeseershop I've seen the WF2IR which can do the same and is much cheaper.
Which one of these two would be recommended??
rgrds, Leo
rgrds, Leo
- Jeroen Bartels
Re: Irtrans Wifi
All I know most people here have experience with/use IRtrans.
So if you expect to need some help...
**Jeroen**
Re: Irtrans Wifi
WF2IR looks okay...also the Iphone/Ipad app looks great.
Re: Irtrans Wifi
Hi Leo,
Did you already purchase any of these 2 products?
Im wondering what your experiences are.
Kind regards,
Michiel
Kind regards,
Michiel
Re: Irtrans Wifi
It seems that WF2IR and IRTrans are not quite the same.
I've send the following email to Global Cache;
I've got a quick question.
Im still deciding if i want to buy a WF2IR unit. I checked different online resources
but can't find an answer.
I can read that WF2IR unit has an IR learner built in.
But can this unit also relay IR to IP.
For example, press an IR remote button, and link that to a Homeseer event.
I know i can use an ipad/iphone to relay ip messages to IR through this unit, but is the other
way around also possible? So can it receive and relay IR?
Hope to hear from you.
Hi Michiel,
Thank you for your interest in Global Caché! At this time, we have no mechanism in place for the iTach to
receive and relay IR in the way that you are thinking. Our on-board learner can be used only to capture IR commands.
Please let us know if you have any further questions.
So it seems the difference is that the IRTrans module can also receive IR signals and relay them to IP. WF2IR is just for learning codes
but other then that, IP to IR.
Are there any thinkable solutions where one would need IR to IP?
Maybe if you want to use a harmony remote to trigger homeseer lamp actions? (im not 100% sure my girlfriend would
accept an iPad/iPhone/Android as the only remote left...)
Any other things where it might be usefull to accept IR to IP?
Kind regards,
Michiel
Hi Michiel,
Kind regards,
Michiel
