Xtreamer and RTL gemist. Can it be done? YES IT CAN/!\
Anyone here who managed to get the Xtreamer to access streams from uitzending gemist, or any other interesting streaming sites?
Re: Xtreamer and uitzending gemist. Can it be done?
As fas as I know, this can't be done at the moment. Take a look at http://forum.xtreamer.net/
I use from the same forum the next script -> Xtreamer live
you can put it into the sda1/script dir.
This is a compilation of a few rss video's without UZG this is not insert to this script but mayby soon.
When you whant to insert by yourself a rss feeds use this script to the menu.rss
If you have added a new RSS, I love my recommended
Grtz,
<item>
<title>NOS</title>
<link>http://feeds.nos.nl/journaal07uur</link>
<media:thumbnail url="http://www.dafne-entrepreneurship.nl/PublishingImages/NOS%20JOURNAAL.jpg" />
<mediaDisplay name="threePartsView" sideLeftWidthPC="0" itemImageXPC="5" itemXPC="20" itemYPC="20" itemWidthPC="65" capWidthPC="70" idleImageXPC="45" idleImageYPC="42" idleImageWidthPC="10" idleImageHeightPC="16">
<idleImage>image/POPUP_LOADING_01.jpg</idleImage>
<idleImage>image/POPUP_LOADING_02.jpg</idleImage>
<idleImage>image/POPUP_LOADING_03.jpg</idleImage>
<idleImage>image/POPUP_LOADING_04.jpg</idleImage>
<idleImage>image/POPUP_LOADING_05.jpg</idleImage>
<idleImage>image/POPUP_LOADING_06.jpg</idleImage>
</mediaDisplay>
</item>
Grtz,
__________________
I don't use a HD in/on my Xtreamer (all content is on my NAS device) Is it possible to use this procedure as well ?? On a USB stick maybe ??djdive wrote:I use from the same forum the next script -> Xtreamer live
If you have added a new RSS, I love my recommendedCode: Select all
<item> <title>NOS</title> <link>http://feeds.nos.nl/journaal07uur</link> <media:thumbnail url="http://www.dafne-entrepreneurship.nl/PublishingImages/NOS%20JOURNAAL.jpg" /> <mediaDisplay name="threePartsView" sideLeftWidthPC="0" itemImageXPC="5" itemXPC="20" itemYPC="20" itemWidthPC="65" capWidthPC="70" idleImageXPC="45" idleImageYPC="42" idleImageWidthPC="10" idleImageHeightPC="16"> <idleImage>image/POPUP_LOADING_01.jpg</idleImage> <idleImage>image/POPUP_LOADING_02.jpg</idleImage> <idleImage>image/POPUP_LOADING_03.jpg</idleImage> <idleImage>image/POPUP_LOADING_04.jpg</idleImage> <idleImage>image/POPUP_LOADING_05.jpg</idleImage> <idleImage>image/POPUP_LOADING_06.jpg</idleImage> </mediaDisplay> </item>
Grtz,
Thanks,
I'm not sure, but you can try it to made a map scripts on your USB-Stick and reboot the Xtreamer.
__________________
Thank you for the info.
So after copying the map to sda1/scripts how do I access it with Xtramer?
Is it under the Xtreamer's Meda Library or Internet or????
UPDATE.. Found it.. It is under Internet > Xtreamer Live!
WOW.. Thats a lot of extra channels (55)
And when this 55 channels is not enough use this script
link
This is the default xLive9 file of the forum but a insert the NOS etc.
I have delete one page but you see this soon when you download it
__________________
Nice one.djdive wrote:And when this 55 channels is not enough use this scriptlink
To bad that I'm missing my fav. channel's (the deleted one)
Anyother place to find this missing page
you can download it from here -> link enjoy
update, when you insert this code in one of your *.rss pages you can use a kind of "uitzending gemist" for NOS, RTL, SBS6, etc
(note, a few extensions can not be viewd to the xtreamer but mayby with i small update this must by solved i hope
btw i havent' a nice jpg for it so i use the one of rtl gemist
<item>
<title>Uitzending gemist</title>
<link>http://www.microchange.nl/uzg/rss.aspx</link>
<media:thumbnail url="http://www.webkey2.nl/btv/images2/editienl.jpg" />
</mediaDisplay>
</item>
__________________
GREAT!djdive wrote:btw i havent' a nice jpg for it so i use the one of rtl gemist
I'm using <media:thumbnail url="http://www.ohmnet.nl/uploadedImgs/Uitzending_Gemist(Home.jpg" /> for the jpg
The feed does showup nice on my Xtreamer, but till now I did not find a working stream for the RTL uitzending gemist.
djdive,
Can we somehow use this in the Xtreamer?
http://www.rtl.nl/service/gemist/device/feed/index.xml
Nice, tonight i will trying something i have mayby a idea.
__________________
I made a small "custom" xml file pointing to the .mp4 files.djdive wrote:Nice, tonight i will trying something i have mayby a idea.
The feed does showup on the Xtreamer, but when trying to load the .mp4, the Xtreamer crashes.
Maybe you have more luck.
I do not get it. For some reason some .mp4's are okay to play, but NONE work from the link that I posted.Noel wrote:I made a small "custom" xml file pointing to the .mp4 files.djdive wrote:Nice, tonight i will trying something i have mayby a idea.
(They all crach my Xtreamer.)
Yahoooo... It's working
let me do some tweaking and I'll post what I have...
