According to two of our french colleagues upgrading to the latest version of HStouch Server, when using HSPro, could cause some problems with your HSpro license becoming invalid.
http://translate.google.com/translate?j ... l=fr&tl=en
I haven't upgraded myself so I can't speak on this matter directly, but I thought I'd let everybody know to double-check this before jumping on the upgrade. This could maybe just be an issue of them not running the right version of HSpro as you need to be running HS 2.4.0.46 in order to upgrade.
Hspro:
http://board.homeseer.com/showthread.php?t=142096
Hstouch + server:
http://board.homeseer.com/showthread.php?t=142164
HSTouch Update 1.0.0.41 Server plugin 1.0.0.16
Re: HSTouch Update 1.0.0.41 Server plugin 1.0.0.16
Ik heb dat probleem inderdaad ondervonden vannacht na de update van HSTouch en de Server plugin.
Nadat ik HomeSeer geupdate had naar de laatste versie .46 was het licentie probleem weer weg.
- Antoon
