Can anyone help me in finding a way of measuring water consumption at my house ?
I have a Altair Sappel French made watermeter. I have a HS 2.4.0.11
Thanks
Vic1743
Watermeter and Homeseer
- b_weijenberg
Re: Watermeter and Homeseer
If this meter has a dry contact or a possibility to add such a contact ( for example http://www.planete-domotique.com/compte ... lsion.html ) you can use the RFXMeter + RFXPulse http://www.rfxcom.com/sensors.htm#70095
Hello friend,
thanks for the info. I think i will buy this watermeter as the one i have is located about 100metres away from my house.. So i will add a second watermeter at the main water inlet..
Do you have an idea of how homeseer can display the information like stats or events, trigger ? There is currently no plugin available from homeseer for water meter reading.. Is it done using scripts or any database server ?
thanks very much for your help
Vic1743
Vic1743
- b_weijenberg
The RFXCOM plug-in is available in the Homeseer updater.
A Charts program (also for the water meter) is available http://www.jphuddlestone.co.uk/rfxcharts/rfxcharts1.htm
hi again,
Sorry i was off for a few days, just read your message..
THanks for the tip. I will have a closer look at RFXCOM product. Thats nice to know there is one product that can do it..
Ill let you know the outcome...
Regards
Vic1743
Regards
Vic1743
Hi
that sounds great!! Im now contacting RFXCOM and i will probably order unit.
I appreciate very much your help since ive been looking for long time for a watermeter monitoring system
Ill let you know my findings
Cheers
Vic1743
Cheers
Vic1743
